Castaic Lion
Santa Clarita, CA
Good Sam RV Club
I can't believe the number of units available.... Has anyone got an opinion (LOL) about which units appear to work best given an RV application? Do you have to have one for each tv, will they operate with the batwing signal boosters?
Should I just give up television and bring along a bunch ov DVD's?
dbbls
Missouri
Good Sam RV Club
Don't believe I've ever seen a HD converter box. All I've ever seen are Digital converter boxes.
edited 11/16/08 12:49pm by dbbls *
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
OnaQuest
Raleigh, NC
Good Sam RV Club
First, they are not HD (high definition) converter boxes. They are DIGITAL SIGNAL converter boxes. They convert the digital signal back to analog so your old tv can receive it.
They will work with your current antenna and booster.
I like the zenith best. your mileage may vary.
Dyslexics of the world... UNTIE Visit www.Dyslexics.moc
ronfisherman
SE Michigan
Good Sam RV Club
I have installed several DTV boxes. They all work OK. But some have better controls. The ones sold at Wal-Mart have the fewest features. The best I have seen so far are the Digital Stream sold at Radio Shack. You will need one box for each TV in your RV.
Kodiak Chassis Class C Rally July 15th -18, 2010
baysalr1
Boones Mill,VA
Good Sam RV Club
I have both the Digital stream and the RCA unit. Both of these are top rated. Of the two I much prefer the RCA. Larger easy to use buttons on the remote and seems to be more user friendly. They work just fine with the booster and can feed more than one tv if you use a ant cable spliter which you are probably already using. Since all of these boxes only come with an IR remote, as long as you have line of sight from the remote to the converter it will operate both tvs (same cannel though).
Baysalr1
1993 36' Pace Arrow 8.3L DP
1993 36' Catalina SV - Quadrant II
"Twenty years from now, you will be more disappointed by the things you didn't do than the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. " - Mark Twain
Dutch_12078
Great Sacandaga Lake, NY
We use an Artec T3A Pro with our bedroom TV, and it works fine for us with the batwing. Our living area TV has its own digital tuner, so no converter was needed there.
Dutch
'95 Coachmen Catalina 322XL
F-53 chassis, 460 V8
Bigfoot EZE-Leveler jacks
pdoucet
MA
Good Sam RV Club
You do need one for each TV. I got the DTVpal at Sears (marketed by Dish) and it works great. In my driveway with the batwing all the way down I get the Boston stations 30 miles away. If I go to analog passthru mode all I get is snow!
Pierre
TechWriter
Green Bay, WI USA
dbbls wrote: Don't believe I've ever seen a HD converter box. All Ive ever seen are Digital converter boxes.
All converter boxes are digital.
Most convert boxes output SD (Standard Definition) TV & are intended to be connected to SD TVs.
However, there is at least one HD converter box made by Samsung.
But why would you buy an HD converter box?
- You don't need it if you're hooking up to a SD TV.
- You probably don't need it if your hooking it up to an HD TV -- because most HD TVs have built-in TV tuners, so you don't need a converter box with them.
If you want HD & have the $$$, skip the converter box & buy an LCD TV.
Tom
2004 34' Sea Breeze LX 8341
Vortec 8.1L & W-22
w/Xantrex RS2000 inverter/charger +
Xantrex XW-MPPT60-150 60A Charge Controller with 760W (3/4 KW) of Kyocera solar
SCVJeff
Santa Clarita, CA.
As Tom says, there ARE real HD converter boxes, the only difference is that they average about +$100 difference and are NOT covered under the converter coupon program.
I have lost count on how many boxes now in the office (for evaluation), but my two current favorites are the Digital Stream DTX9950, and the DTVPal. Both units are Pass-Thru, and a MUST HAVE. I have the Digital Stream in the RV because I really like the menu structure, but it runs hot and draws almost twice the power of the DTVPal. Also the DTVPal runs on a 5V wall-wort, so you can whip a simple 12 to 5V regulator and bypass the inverter. Since my TV's are both 110VAC that didn't really matter, although the extra current draw may sway me.
Jeff - WA6EQU
rjf7g
Virginia
Good Sam RV Club
I don't like the Insignia sold at Best Buy. I replaced it with a Magnavox from Wal-Mart and am getting much better results.
1992 Fleetwood Tioga Montara Special 27 Class C
2007 Gulfstream Innsbruck 36FRS Park Trailer
