RV.Net Open Roads Forum: Truck Campers: Diesel Soot
 > Diesel Soot
Truck Campers Related Tips
trvsdad1
peoria,az.
Good Sam RV Club
Posted: 07/16/09 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Anybody put a "Turn Down Tip" on their diesel pick-up in an effort to reduce soot getting on their boat, or ? trailer? If so did it work? Thanks in advance.
TRVSDAD1
bldrbuck
Boulder, Colorado
Good Sam RV Club
Posted: 07/16/09 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
A turn-down may help a little, what will help more is driving so there is less soot. If you see soot drop a gear and slow down.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
d3500ram
colorado
Posted: 07/16/09 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Diesel soot on truck/ camper = badge of honor... wear it proudly!
2005 Dodge 3500 SRW, Qcab, NV-5600, diesel, 4WD, Helwig sway bar, 9000XL
trvsdad1
peoria,az.
Good Sam RV Club
Posted: 07/16/09 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
My F350 is an auotmatic, the problem is towing for 3.5 hours at 65 mph. When we get to the lake (due to wagon back effect) the boat cover is dirty with exhaust soot. If I tow without the cover on the boat the upholstry and carpet get dirty. Just looking for an improvement.
Dome
Southwest Washington State
Posted: 07/16/09 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
I put a tip down on my rig and it does seem to help. I no longer have a black jack.;o)
Big Bruce
Anthony Fl.
Good Sam RV Club
Posted: 07/16/09 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
I put a extension with a turn down on my Dodge Dually to keep the soot off the fender and bumper and it worked very well.
Big Bruce
2006 Dodge, Dually, CTD, Quad Cab, 4 X 4, Automatic/ 2006 31' Cougar F/W
Hauling (1) 2009 Harley Heritage Classic and (1) 2009 Softail Deluxe.
Or Gone Fishing - 17' Carolina Skiff with Yamaha 75Hp 4 Stroke.
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/16/09 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
On our diesel van, the exhaust pipe hangs down very low below the body. That seems to help some.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
KKELLER14K
BEAVERTON OREGON
Posted: 07/16/09 11:51pm Link  |  Quote  |  Print  |  Notify Moderator
You could by a gasser...LOL! If you want to talk soot go to larger injectors, then it really comes out....I don't think there is any great mod to really get it out of the way. I only get it on my rear hold down, lucky me!. Have you seen that air deflector that fits on the top of the TC kind of like a set of fins? It helps keep dirt and dust from collecting on the back. Diverting the air down the back might help push it out of the way.
Gary3
Windsor, ON
Posted: 07/17/09 05:36am Link  |  Quote  |  Print  |  Notify Moderator
You could buy a 07.5 Diesel all the soot goes into partical filters and your oil, which has to be changed more often.
Gary  Lance  1181 solar Gen.
Reddog1
El Dorado, CA
Posted: 07/17/09 09:12am Link  |  Quote  |  Print  |  Notify Moderator
I have a "Turn Down Tip" on my truck. Before the "Turn Down Tip", I would get soot on the corner of my TC, about 12" to 18" up the side. I never really noticed if I got it on the Zuki when towing it. After installing the "Turn Down Tip", I no longer get the soot.
My tip is turned almost straight down, and gets a little soot of the front edge, about 1/2" up the tip. I think I will have to turn it a little to prevent that soot.
Under the right circumstances, I can get a lot of soot. I do have a highly modified fuel system, including injectors.
Wayne
 > Diesel Soot
