RV.Net Open Roads Forum: Fifth-Wheels: Proper Jacking Points for Fifth Wheel
 > Proper Jacking Points for Fifth Wheel
Fifth-Wheels Related Tips
GlenO
Terry, MS
Posted: 08/09/09 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
I have been lucky out on the road and haven't yet had that flat but know it will come one day. I carry a 12T bottle jack. Everything I can read talks about lifting either on the frame right behind the springs. I have seen such in pictures within some of the RV manuals but they are always using a big commerical type jack, ultimately lifting both tires off the ground. I have seen the plastic deals where you simply pull your good tire up on it to change the other flat tire. My trailer has the MorRyde stablizer system on the springs. Anyone have any experience using the drive on lift for changing a flat out on the road? Sure looks easier than having to mess with a bottle jack and blocking?
marvmarcy
Polson, MT, USA
Good Sam RV Club
Posted: 08/09/09 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
I have not used any drive-on type lifting device other than to support both axles when leveling the fiver. I don't think I want to use something like that when I've already got a couple of good 8T bottle jacks. I've changed two tires on my fiver and used the bottle jacks at the axle rather than at the frame. I also have Moryde suspension but with tandem duals supporting a 20K# trailer (16,500# on the axles). For safety, I also support the fiver with jack stands. I lift the tire barely high enough off the ground to get the inflated tire back on. Unfortunately, both flats were inside tires.
I guess I'm missing something, because I don't understand why I should jack the frame rather than the axle on my fiver. I put less stress on the axles, springs and Moryde and it should be as safe if not safer.
Marv
2001 Volvo VNL42T420, ISX450/1650, super 10sp w/GearMaster
2003 Newmar Mountain Aire 38RLRK (20K GVWR, tandem duals)
Piaggio MP3 400 scooter
RVing since 1979 - Fulltime since 2000 (mostly CO, MT, NC & Key West)
Retired USAF
Big Bruce
Anthony Fl.
Good Sam RV Club
Posted: 08/09/09 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
I have always used a bottle jack and place it on the axle u bolt or the plate on the bottom of the u bolt depending on the instillation of the u bolt, up or down.
Big Bruce
2006 Dodge, Dually, CTD, Quad Cab, 4 X 4, Automatic/ 2006 31' Cougar F/W
Hauling (1) 2009 Harley Heritage Classic and (1) 2009 Softail Deluxe.
Or Gone Fishing - 17' Carolina Skiff with Yamaha 75Hp 4 Stroke.
ryoung
Indiana
Posted: 08/09/09 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
I always used the shackle plate under the spring also. Could never understand why this is not recommended. Not putting the jack under the round axle tube I can understand. But why not the shackle plate?
ryoung
2004 Dodge 3500 Dually HO CTD 6 sp 4.10
2004 Lance 915
Vulcaneer
Northern New England
Posted: 08/09/09 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
I use the drive on ramp. Works great on hard surface. Will sink in on soft ground. Carry a piece of plywood, or a 2X6 to go under it on soft ground. Much better than jacking. Quicker, safer for any wheel maint. And for adjusting brakes, it is out of the way.
If using a jack, be sure to hitch the trailer to the truck, rather than expecting the front elevators to hold the weight.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
Bluefreight
traveling
Posted: 08/09/09 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Do NOT jack on the axle of a Mor/ryde system, you will damage it. Consult your manual or better yet contact Mor/ryde at (574) 293-1581. I could tell you were to jack, but I'd rather you get the correct info direct.
Veebyes
Bermuda
Posted: 08/09/09 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
I carry around a 12" block of wood to put the bottle jack on. Also leave trailer on the truck to eliminate any twisting on landing legs. As per earlier post, position jack just aft of rear spring hangers.
2007 Alpenlite 34RLR
racquet9
Mountain Iron, MN
Good Sam RV Club
Posted: 08/09/09 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
Were did you get the tire change ramp?
2006 Chevy 3500 LT3 D/A LBZ CC LB Dually. Xtreme floor mats, Luverne Side Steps with Dually Box Extendtions, Banks 4" Monster Exhaust (no muffler), Banks Ottomind 6 Tuner, Banks Speed Brake, Cameo F36FWS, full timing with our 2 Shelties
wandering1
Posted: 08/09/09 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Wooden blocks and 12 ton bottle jack under the frame has always worked great for me.
HR
CactusJohn
Scottsdale, AZ
Posted: 08/09/09 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
My axles are made by Lippert Components and their manual says, “Warning: Lift unit by the frame and never the axle or suspension.” My 5er’s manual says the same thing.
2007 Ameri-Camp (RIP) Summit Ridge SF27RK 5er
2008 F250 Lariat SuperCab, 6.4L PSD
Reese 16K Kwik-Slide with BedSaver
