RV.Net Open Roads Forum: Tech Issues: No 12v in coach?
 > No 12v in coach?
Tech Issues Related Tips
Lt46
Cape Cod, Ma.
Posted: 08/14/09 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Need some help. MH is in signature. I've been plugged in to 110v, 24/7 for the past 2 months. Today, took the MH out for a spin around the block and realized I had no 12v being supplied to the coach... lights,pump,fridge etc.etc.
I do not have a manual 12v cutoff (as in knife switch), but do have a dash 12v disconnect switch. Evidently I inadvertantly activated this disconnect at some point. I had a devil of a time getting this latching solenoid to work. It took frequent cycles of engage, disengage to get it to switch over. Once it did, all 12v systems operated normally.
My question is; is this the result of age? lack of use? malfunction?
All electrical wiring connections look clean and are tight.
I guess I'm trying to determine if this was just a fluke or a warning.
Any thoughts?
Peter & Dawn
97 Winnebago Adventurer 37RW
91 R2500,454 Chevy Suburban
96 Prowler 27X SOLD
Yamaha EF2800I
IAFF L-792
NORM WADDELL
PENSACOLA FL 32514
Posted: 08/14/09 08:17am Link  |  Quote  |  Print  |  Notify Moderator
The 12 Volt disconnect relay
needs 'exercise'. If it is
working properly now, and if
you 'exercise' it periodically,
it will probably contine to work.
This is true for all working
components of the RV..........run
the engine, spin the fans, run the
air conditioner and furnace, all
at least every few months.
L NORMAN WADDELL
30 FOOT ALLEGRO
SATURN TOAD
WIFE AND 2 DOGS SUGAR BEAR & COCO BEAR
tvman44
Southwest Louisiana
Posted: 08/14/09 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Lack of use.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
mtdew999
Backwoods, Oregon
Posted: 08/14/09 09:29am Link  |  Quote  |  Print  |  Notify Moderator
It always amazes me how an RV deteriorates when left to sit. In RVing, "use it or lose it" is very true.
Lt46
Cape Cod, Ma.
Posted: 08/14/09 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
OK, will add "exercise switch" to the list! Thanks.
 > No 12v in coach?
