RV.Net Open Roads Forum: Tow Vehicles: How accurate is your fuel range calculator
Search only in Tow Vehicles
 > How accurate is your fuel range calculator
Tow Vehicles Related Tips
eightballsidepocket
San Jose, California, USA
Posted: 08/24/09 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
My 2005 2500 Dodge Cummins Computer is "dead on"! Got the 3:73 rear end with the Automatic. Factory tires still....
Regards, Eightballsidepocket
2005 Dodge Ram 2500 SLT 4x2 Quad Cab, Cummins, 48RE Tranny, Lg Bed, Line-X Spray-on Bed Liner.
06 T25BS Komfort Trailblazer TT
"If you can't say it in person, it isn't worth saying while hiding behind an anonymous P.C.!"
Big Bruce
Anthony Fl.
Good Sam RV Club
Posted: 08/24/09 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have talked to a lot of Dodge owners and you are the first to say it is close to being accurate.
Big Bruce
2006 Dodge, Dually, CTD, Quad Cab, 4 X 4, Automatic/ 2006 31' Cougar F/W
Hauling (1) 2009 Harley Heritage Classic and (1) 2009 Softail Deluxe.
Or Gone Fishing - 17' Carolina Skiff with Yamaha 75Hp 4 Stroke.
msjdbman
SW Michigan
Posted: 08/24/09 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
FOr my 08 Duramax in sig, the mpg is pretty darned accurate, as is the fuel used. Fuel used differences are station related. One that I use routinely is exactly the same. Kind of tells the story on accuracy tolerances at the pump for other stations doesn`t it. But since the truck tells me I`m low on fuel at 18.8 gal used, it quits reading remaining range shortly there after.
2008 Duramax/Allison LT2 Crew cab Standard Box. Hellwig Air Assist.
1996 Terry 27 5J
Chicken McNugget
Colorado
Posted: 08/24/09 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
The lie-o-meter on my PSD Excursion usually shows about 25 - 27 mpg highway - actual calculated mileage has been in the 22 - 23 mpg range. I have not tried it towing or paid much attention to miles remaining read out, with a 44 gallon tank at 23 mpg she goes a long ways :-)
2000 Ford Excursion 7.3l PSD
2009 Shamrock 19T
www.highplainsphotographer.com
mac01
Berryton, Kansas
Posted: 08/24/09 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
My '07' 2500 Dodge is pretty accurate when towing. I checked it 3 times in our last outing and it was less than .2 every fill up. Hand calculating was always higher MPG. When not towing it's off by .5 or more.
2007 Dodge 2500 6.7L CTD quad cab 4X4
2005 Jayco 325BHS
countryrose
Redding, Ca
Good Sam RV Club
Posted: 08/24/09 11:16pm Link  |  Quote  |  Print  |  Notify Moderator
I think it calculates your range based on your current average mileage. So if you have driven 100 miles and are averaging 10 MPG and you have a 30 Gal Tank it will tell you that you can drive another 200 miles. That being said if driving conditions change so will you average mileage, resulting in changing your remaining range.
Not sure how well I explained, I hope this helps.
Gary
2009 Bighorn 3400RL
2008 Chevy 3500HD DRW
DuraMax w/allison
hotpepperkid
Chino Hills CA
Posted: 08/24/09 11:17pm Link  |  Quote  |  Print  |  Notify Moderator
Clattertruck wrote:
hotpepperkid wrote:
Clattertruck wrote:
There is a reason that many folks call them "lie-o-meters".
Since I intalled a replacement 65 gal fuel tank my meter says im close to empty when I have 35 gallons left in the tank.
Did you recalabrate the computer now that you have a different capacity.
hpk
I have the latest flash which helped some. Can the dealer adjust it?
Dont know about the 08's but on mine all they have to do is plug in the computer go to fuel cap and enter your new fuel capacity. It took me three trys to find a dealer to do it. First one I called said it couldnt be done, but I already knew it could so I called another dealer they said if it wasnt OEM they wouldnt touch it so I called another dealer they said they didnt know how. I told them that I knew how they said bring it in we will fig it out. It was real simple you can also change the tire size so the speedometer reads correct. Go to here
they will know for sure about your year
hpk
2000 Ford F-350 SRW 4X4 PSD Jayco Super Lite 29.5RKS (31') 5th wheel 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
