RV.Net Open Roads Forum: Tech Issues: converter location
 > converter location
Tech Issues Related Tips
GoGo Gadget
VA, USA
Posted: 09/11/09 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Anyone know where it is located on a 98 Winnebago Adventurer? The manual says behind a lower panel in the galley, living area or under the bed. The panel in the galley onle has the 110VAC breakers. Nothing in the living area or under the bed.
1998 Winnebago Adventurer 35M
Used to be that we "world proofed" our children. Now society wants to "child proof" the world.
Lt46
Cape Cod, Ma.
Posted: 09/11/09 09:27am Link  |  Quote  |  Print  |  Notify Moderator
On my 97 Adventurer it is under the kitchen sink, on floor, against outside wall.
Peter & Dawn
97 Winnebago Adventurer 37RW
91 R2500,454 Chevy Suburban
96 Prowler 27X SOLD
Yamaha EF2800I
IAFF L-792
toprudder
Raleigh, NC
Posted: 09/11/09 11:19am Link  |  Quote  |  Print  |  Notify Moderator
Some converters are part of the circuit breaker and DC fuse panel assembly, perhaps that is yours. My current camper is that way. My old motorhome was a seperate unit mounted under the sink behind a panel. I found it by tracing the large positive wire from the battery through a hole in the floor.
Bob, Martha, and Matt.
Tucker, the Toy Poodle
'09 K-Z MXT20, '07 Chevy 2500HD Duramax
Toprudder.com
GoGo Gadget
VA, USA
Posted: 09/11/09 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
My wife asked, "Is it under the sink?" I replied, "No way. You would not put electrical stuff under the sink close to water if you had a leak." Guess I was wrong. Looks like it is under there under a plastic cap." I need to replace it and my batteries. I was planning on stopping at Camping World on our way out tonight and replacing it all. I assume there is not much to the converter, just hook up new wires right?
toprudder
Raleigh, NC
Posted: 09/11/09 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
Pretty much, as long as the replacement converter is rated for the same (or less) current than the old converter. If you go up in current rating, you may need to replace the wires between the battery and converter, as well as any fuse or breaker in that path. The only other consideration would be mounting the converter, it may not have the same bolt pattern as the old one.
