RV.Net Open Roads Forum: 110 vt. Freezer While Boondocking?
Search only in Public Lands, Boondocking and ...
Open Roads Forum  >  Public Lands, Boondocking and Dry Camping
 > 110 vt. Freezer While Boondocking?
Public Lands, Boondocking and Dry Camping Related Tips
Kinot1
London, Ont., Canada
Posted: 09/29/09 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
I have a small (3.7 CF) freezer and I am "hoping" that there might be a way to use it while boondocking. Is there anyway that I can? I do have a on-board 7000 genny, on my MH, as well as an "outside 1850 genny". I hope to boondock about 60 mi. from a large city, where I can stock up on meat etc.
Is it possible?
Thanks
John
'99 Ford F-350 Dually, 7.3L PSD, Longbox
2001 Jayco Designer 32' (35'9" measured) Triple Slides
'96 Sebring Convertible
1 15' Kevlar Canoe With Paddles
'98 Yamaha V Star 650 Classic
And More Stuff
bldrbuck
Boulder, Colorado
Good Sam RV Club
Posted: 09/29/09 11:38pm Link  |  Quote  |  Print  |  Notify Moderator
As long as you have fuel for the generators you should be fine. You should be able to shut the freezer off during quiet hous if you don't open the door.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
Crazy Ray
Monroe,La
Posted: 09/30/09 07:35am Link  |  Quote  |  Print  |  Notify Moderator
anything is possible go for it.
RET ARMY , DW Donna , Summer (Furkid) . Class A, 2000 Gulf Stream, 4 SAMS 6VOLTS, DIRECTV, YAMAHA 2400 GEN , TOW 97 Wrangler/Honda CR V. Garmin GPS 7200 . "Living Our Dream". NASCAR FAN (14,18,,20,11) Love CO & NM
2oldman
Indio CA
Posted: 09/30/09 09:58am Link  |  Quote  |  Print  |  Notify Moderator
If you're there in winter you won't need a freezer.
skipnchar
Topeka Kansas USA
Posted: 09/30/09 10:34am Link  |  Quote  |  Print  |  Notify Moderator
No problem as long as you're not camping next to me. I'd HATE to listen to your generator when I'm boondocking to get AWAY from noise etc. Good luck / skip
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
lawnboy1
Palmyra,Pa
Posted: 09/30/09 11:03am Link  |  Quote  |  Print  |  Notify Moderator
i take a 5 cu ft freezer with me on trip to texas ,and only plug in at night. nothing melts till we get there. just lid closed when as much as possible ,should work out with a couple hrs running electric.
T_Bone
Arizona
Posted: 10/01/09 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Is it possible?
Thanks
Hi John,
Buy a extra battery then use a inverter too run the freezer then use the genset to recharge the battery's. Or buy a solar 130w PV, about $257, that will keep up with your battery charging. Much more efficient.
I would make sure your freezer is a manual defrost as a auto defrost uses alot of juice that's not needed. I would also line the outside walls, top & bottom with 2" styrofoam, not in the compressor area. Add a external reading thermometer.
If your camping next too me, then I've been known to run off a couple hundred rounds in the 44mag at 5am, if'n it's safe too do so. I figure if you can like your genset noise, you can like my 44mag noise or move over 10,000a or so.
T_Bone
02 F350, 4x6, CC, DRW, PSD, 6spd, 3:73
32ft Serria 10yr 100% Solar
Please do not trust everything you read on the internet. Use only valid engineering information from well established Companys.
Buy UNION Work UNION
It pays off in the long run !
pnichols
Santa Cruz Mountains
Posted: 10/01/09 10:54am Link  |  Quote  |  Print  |  Notify Moderator
"Is it possible?"
John, I guess you already own a small freezer .... probably one that is designed for home use to run only on 110V AC?
If you ever want to pick up a new small freezer specifically designed to be very efficient on 12V battery/solar power for camping use, here are some of the best:
http://www.bigfrogmountain.com/Engel_Products.html
Phil, 2005 E450 Itasca 324V Spirit
pnichols
Posted: 10/01/09 11:09am Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 10/02/09 09:09am by pnichols *
Kinot1
Posted: 10/05/09 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
T-Bone, if you have a magazine that holds a "couple of hundred rounds",,,,,,,,,that must be a heck-of-a-gun you have. LOL In all seriousnous, I would ONLY use the genny between the hours of 10 and 7. Believe me, I would NEVER inconvenience anyone around me intentionally or unintentionally.
Thanks for all of the replies.
BTW, thanks for the info re the styrofoam.
Nice to know so much info is available here.
