skipit
Full time - somewhere in the USA
All was working well this morning. For reasons unknown hot water flow dropped to less than 1/2 of normal. No one was messing with any plumbing, no one was under the coach storing stuff, nothing unusual was going on... Cold water flow is unaffected.
We have a 2006 Winnebago Adventurer.
Anyone have any ideas what might be causing this????
2001 Chevy Tracker
Wonderful Wife/Co-Pilot/Best Friend for 38 years
joppa
Northeast
water filter under the sink?
The World is a book, and those who do not travel read only a page. ~St. Augustine
2007 Foretravel Nimbus
Cummins ISM 500HP
Allison MH4000w/Retarder
Don Don
Pleasant Grove, AL {Suburb of Birmingham}
Good Sam RV Club
joppa wrote: water filter under the sink?
Water filter would effect both flows if that were the problem.
skipit
I guess it could be but it only affects hot water. Cold water is normal.
minisprint91
Hudson Ma.
Good Sam RV Club
I would try draining the hot waster tank and refill it might be air bound Just a thought
Polishnurse
Schodack, NY
I don't know where your hot water heater is located, but mine is under the sink, perhaps some put something in there or where ever it is and knocked the by-pass valve partially closed. Bill
another thought would be your anode or heating element broke some flakes off and is blocking the outlet.
Another thought - sediment build up on the bottom the tank is blocking the fill tube, if you have a heavy mineral problem, it should be drained at least once a month to prevent build up.
You can't take the Fisherman out of this Camper
Ontario, Canada
Good Sam RV Club
Have you checked the tap screens?
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: 2002 Cougar 276EFS & 2005 Laredo 29GS; 2002 GMC 2500HD Ext Cab 4x4; (Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
jwmII
out west
My vote goes to the water heater bypass valve(s). It(they) may have been inadvertently tweaked restricting flow out of the water heater.
jwmII
Dynasty40
Northern California
Is it all faucets or just one???? If it's all faucets, check the bypass valve or water heater for an obstruction. If it's just one, the screen is probably plugged. You might have a separate screen just prior to the HWH that could be full of sediment. Do you have a separate filter on the HW line? Lots of things, all minor and easily fixable....Good luck...let us know what you finally find....Dennis
Dennis and Debi
Monaco Dynasty Baron 40PFD
Towing a Chevy HHR W/
ReadyBrute
BBC0
Alberta, Canada
My shower head has a valve in it. If you shut off the water with this valve but leave the faucets open water can recirculate lowering the flow at the other faucets. Just ensure that the shower/tub faucets are closed.
