RV.Net Open Roads Forum: Tech Issues: Refrigerator ????
 > Refrigerator ????
Tech Issues Related Tips
limit 5
Tyler
Posted: 11/01/09 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Just got into this RVing thing and need alittle help,the refrigerator my 95 Jayco has is a gas or electric frige,the problem I am having is the LP side works when it wonts to,no matter how level it is sometimes it will not lite,next we use it it works,checked the burner area and the vent and have not found anything.ANT IDEAS WILL BE GREAT.Tried to do a search and could not find any help.
mike4947
N. Syracuse, NY
Good Sam RV Club
Posted: 11/01/09 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Get the make & model off the fridge and you can download a service manual from Here
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
They say you learn by your mistakes, in that case I must be a genius.
Rolling Condo
South Carolina
Posted: 11/01/09 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
Some more information would be helpful, make and model. Does it work on the electric setting?
'90 GMC R2500 7.4L
'90 Avion 34V
Cummins Onan P4300ie
Reese Dual Cam HP
Prodigy
Hurricaner
Hurricane Utah
Posted: 11/01/09 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
Let me guess, a dometic 2611.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
limit 5
Tyler
Posted: 11/01/09 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks I will give it a try.
limit 5
Tyler
Posted: 11/01/09 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Works perfect on electricity,I am not at the trailer at this time or i would have gotten the numbers and posted them.
dougrainer
Carrolton, Texas
Posted: 11/02/09 05:37am Link  |  Quote  |  Print  |  Notify Moderator
Always post year/model of RV. Model and S/n of appliance. Helps a lot.
Does the CHECK light come on when it does NOT light on LP? Doug
limit 5
Tyler
Posted: 11/02/09 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
1995 Jayco 207 SL Eagle,it has a norcold fridge,to dark to get #s tonight,when I try to lite you here it clicking and there is a flame at the pilot,when it quits clicking the flame goes out and a red X appears on the control panel,I have 12 volts and I would assume gas because of the pilot flame I get at start up,it works great on 110.
dougrainer
Carrolton, Texas
Posted: 11/02/09 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
The X is the "check" light on a Norcold. There is NO pilot flame. There is just the flame. The odds are you have a defective Spark electrode or a dirty burner (debris). Once you get the model number, I will know if you have a Thermocoupler, but I do not believe Norcold used a Therm on models in the last 20 years. Doug
Dutch_12078
Great Sacandaga Lake, NY
Posted: 11/02/09 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Check the burner for any rust debris that may have fallen down and partially blocked the flame or the flame sensor.
Dutch
'95 Coachmen Catalina 322XL
F-53 chassis, 460 V8
 > Refrigerator ????
