Dave H M
IL
jav may have a point - the separator between the plenums or air control partition in mine was a terrible install.
Also I was gonna mention that my freeze sensor was dangling in the compartment, but apparently that cannot be your case.
good luck
dougrainer
Carrolton, Texas
Krause wrote: Let me run this by you guys- I haven't looked at it but has anyone ever modified their A/C so that it is controlled by a proper thermostat? When I look at mine I don't think it can be done but I find it annoying that it NEVER shuts off. You can set the temp with one dial and set the fan to "Low" or "high" on the ceiling unit. If you set it to high, it really blows and can be very uncomfortable. Seems to me if you could cycle the unit it would avoid some of these problems.
Having said all of that I will get it serviced in the spring.
You have mechanical controls--NO freeze sensor. You do have a Tstat (mechanical). Have you tried turning the tstat down a little or do you have the tstat on full cold? It is possible that you have a defective Tstat. On your system, you need to make sure the tstat sensor tube is in the correct place. You also need to make sure that the exhaust and intake is adequately sealed to prevent leakage. Your type model, it is common to have freeze ups on Low Fan/Cool. You can modify the system to include a Freeze control and a ceiling or wall tstat, but would probably cost $200 to $300 for the parts. Doug
mikestock
Vestavia Hills, AL, USA
Had a problem with the Dometic 15k unit in my old fifth wheel. It froze up at night. I replaced the freeze sensor with an adjustable timer that cycled the the unit off and on and prevented freeze up. In the daytime I turned the timer off and let it run full time.
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Honda EU2000i, Porta Bote with 6HP Nissan and sail kit, S&W security system
nelson
Clio,Mi USA
Good Sam RV Club
Take the cover and filter off. You soul be able to see the temp censor. It should be located in the cooling fins not hanging free. I had the same issue and compared my other AC to the one that was freezing up and the one freezing up the censor was hanging free unlike the one that was working as it should so I put the censon in the same location as the correct working AC and have not had a problem since. Hope this is your problem as it is a free fix.
2002 Damon Challenger 348 Ford V10
Blue Ox Auto Stop and Aventa II Tow Bar
2001 Ford Sport Trac with Remco Driveshaft Disconnect
Wherever I happen to park
There are two schools and odds are they are both correct. There is also a 3rd issue on SOME models
I have never seen a case of freeze-up that was not due to low-coolant charge. NEVER, and I've seen several cases of it.. That said I'm not a pro. I see others have told you what to do if this is the case
Second school is reduced air flow.. I see you checked the filters but running the fan on HIGH (NOT automatic) has several advantages.. One it warms and dries the evaporator off when it's not cooling, and 2: It masks other sounds (your mind quickly blocks the sound of the blower) And it may prevent freez-up, (I do not know) Also if it is a ducted unit make sure the ducts are clear and not collapsed
The THIRD issue, some models have a "Frost Sensor" this is a metal bulb on a tube usually in a yellow plastic clip that is supposed to be stuck into the evaporator.. In many cases it may have fallen out or not been properly positioned to start with.. CHECK THE SERVICE MANUAL FOR YOUR UNIT before straining your eyes to see if this is the case.
dougrainer
Carrolton, Texas
nelson wrote: Take the cover and filter off. You soul be able to see the temp censor. It should be located in the cooling fins not hanging free. I had the same issue and compared my other AC to the one that was freezing up and the one freezing up the censor was hanging free unlike the one that was working as it should so I put the censon in the same location as the correct working AC and have not had a problem since. Hope this is your problem as it is a free fix.
What you saw was the Freeze sensor. NO Temp sensor is installed in the evaporator fins. The OP has NO freeze sensor. Just a Mechanical Tstat with the standard copper probe sensor. Doug
dougrainer
Carrolton, Texas
wa8yxm wrote: There are two schools and odds are they are both correct. There is also a 3rd issue on SOME models
In your every case of low coolant. HOW did you verify that it was a low charge? Doug
javaseuf
California's Gold Coast
This doesn't apply as we have already established that the OP's unit doesn't have a freeze sensor.
And, just in case the OP is confused with the term "temp sensor", there will be a capillary tube that comes off of the mechanical thermostst and this MUST NOT make contact with any part of the coil or any metal. It should be contained in a rubber "O"-ring on a bracket that insulates the bulb from touching metal.
If this cap tube would touch metal, it would cause the compressor to short-cycle since it would then be sensing the temperature of the cool metal and not the return air temperature.
edited 11/05/09 02:08pm by javaseuf *
Steve
2007 Springdale 291RKL
2009 F150, 5.4 ltr.
1986 Palomino Hard-Side PUP
"Nobody knows how we got to the top of the hill, but since we're on our way down, we might as well enjoy the ride". ("The Secret Of Life", James Taylor).
javaseuf
javaseuf wrote: nelson wrote: Take the cover and filter off. You soul be able to see the temp censor. It should be located in the cooling fins not hanging free. I had the same issue and compared my other AC to the one that was freezing up and the one freezing up the censor was hanging free unlike the one that was working as it should so I put the censon in the same location as the correct working AC and have not had a problem since. Hope this is your problem as it is a free fix.
And BTW, in my years of servicing, I can count on one hand the number of units that froze-up because of low refrigerant. The most common cause is dirty fins on the coil.
edited 11/05/09 02:07pm by javaseuf *
dougrainer
Carrolton, Texas
javaseuf wrote: javaseuf wrote: nelson wrote: Take the cover and filter off. You soul be able to see the temp censor. It should be located in the cooling fins not hanging free. I had the same issue and compared my other AC to the one that was freezing up and the one freezing up the censor was hanging free unlike the one that was working as it should so I put the censon in the same location as the correct working AC and have not had a problem since. Hope this is your problem as it is a free fix.
And, just in case the OP is confused with the term "temp sensor", there will be a capillary tube that comes off of the mechanical thermostst and this MUST NOT make contact with any part of the coil or ant metal. It should be contained in a rubber "O"-ring on a bracket that insulates the bulb from touching metal.
You read my mind on this post. I have 31 years of RV AC service and I can count on 1 hand the number that had freeze ups due to low charge. Doug
