My 2006 dodge 3500 5.9's check engine light came on and stayed on until I refueled. After refueling and restarting the light went off and so far has stayed off. I checked the fuel cap while the light was on and it was tight. Also stopped and restarted the engine several times and the light stayed on until the refueling. Has anyone had this happen?
Thanks
Big Bruce
2006 Dodge, Dually, CTD, Quad Cab, 4 X 4, Automatic/ 2006 31' Cougar F/W
Hauling (1) 2009 Harley Heritage Classic and (1) 2009 Softail Deluxe.
Or Gone Fishing - 17' Carolina Skiff with Yamaha 75Hp 4 Stroke.
No, but have you pulled the code so you can find out what it pertains to? You can do this with the key, takes a second, and takes all the guesswork out of it. The code will disappear after just normal starting for a few times, unless it is an ongoing issue.
RRyall wrote: No, but have you pulled the code so you can find out what it pertains to? You can do this with the key, takes a second, and takes all the guesswork out of it. The code will disappear after just normal starting for a few times, unless it is an ongoing issue.
What has happened with your truck, is that the fuel cap was not tight, or you filled up the unit while running. This tank is a sealed unit and if the cap is loose or off it will trigger a check engine light. The code would read large leak. By turning off the engine and restarting it will reset it self. General this takes three to six cycles
This spring we were heading from Oh to MD, fueled up and about 20miles down the road the check engine light came on. I pulled over and checked the fuel cap-it was tight. The light stayed on, refueled about 1 mile from our destination and the next morning it was off. Ran 2 tankfuls and on the way home fueled up at the same place as we did coming over and within 20 miles the check engine light came on again. Same results after the next tank, the light went off and hasn't been back on since. Have driven about 5k since. I think maybe we got some not up to par fuel As this is the only time that has happened and only following a fillup at this one station. Gary
