RV.Net Open Roads Forum: Tech Issues: Repairing Cracked AC Covers
 > Repairing Cracked AC Covers
Tech Issues Related Tips
LarryJM
NoVa
Posted: 11/06/09 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
Dusty R wrote:
If there cracked because they are rather old, I'd look into replacing them.
Dusty
I agree, just replace it an be done for another 10 years or so. Hitting them with some 303 every 6mo or so will help extend their life some. The replacement cover shouldn't be more than $100 or so unless you have to have it shipped ... so I would look for a local availability.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
chipper
Nampa,Id
Posted: 11/06/09 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
[quote=BIKERK9][COLOR=#000099]Heat and the UV take their toll and make them brittle after a number of years.
Repairing a brittle cover is a temporary fix. Might consider buying a new one.
Yep,when they get old & brittle, save your time, get a new one.
gene
robatthelake
Vancouver Island
Posted: 11/06/09 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Even if You do Patch them They will still fly apart. There are replacements available even on E-Bay!
Rob & Jean
Dutch Star Diesel Pusher ..Tracker 4X2
bill h
coastal reconquista
Posted: 11/07/09 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Quick and dirty would be rough up the area on the outside and build up some epoxy like Marine Tex or JB Weld. Better would be to remove it, rough up the inside and patch and reinforce it with glass cloth and an epoxy resin. Epoxy costs more, but it sticks better.
At the airline, we used only epoxy on airplanes. On stuff that wasn't important, like cargo pods or catering equipment, we used regular old cheap polyester resin.
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
MrWizard
Van Nuys, Ca
Posted: 11/07/09 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
5 yrs should not be considered old
Jim & Carmel
2004 Dutch Star 41'
Connected via Verizon Via Motorola Droid with Android2 OS
mike4947
N. Syracuse, NY
Good Sam RV Club
Posted: 11/07/09 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
One note if they are Coleman units. Their covers are prone to cracking and really need reinforcement. Pop Up Gizmo's makes a brace that stops the cracking. Even the newer "redesigned" covers still crack.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
They say you learn by your mistakes, in that case I must be a genius.
xsmokeyb
Ellensburg, WA
Good Sam RV Club
Posted: 11/07/09 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
My AC cover had some cracks around where it bolted down that I reinforced with an aluminum plate and pop-rivets w/washers
William R. moran
j-d
Sunny Florida USA
Good Sam RV Club
Posted: 11/08/09 10:59am Link  |  Quote  |  Print  |  Notify Moderator
MaxxAir has a replacement for Coleman that is really rugged and lifetime warranted. I had patched ours with aluminum sheet and pop rivets, also added bigger plates where it fastened down.
Now, it was more like 15 years old and lived in the FL sun all its life, but when I put the old one out for the trash, they grabbed it like it had a little substance and it shattered into pieces that we had to sweep up.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
Jeremy626
IL
Good Sam RV Club
Posted: 11/09/09 11:34am Link  |  Quote  |  Print  |  Notify Moderator
I read somewhere that if you get a crack in plastic, in order to keep it from spreading, drill a tiny hole at the end of the crack and that will usually stop it from continuing to spread. Still go the repair route, but I'd drill a small hole at the ends of the cracks to keep them from getting bigger over time.
Jeremy
Rig: 2002 Palomino Stampede S21-SDSL
TV: 2007 Chevy Trailblazer LT 5.3L V8, 3.73
Equal-i-zer, Prodigy BC, Navigon 2100 Max GPS
2009 Trips We've Taken
tommy wilson
southern ca, usa
Posted: 11/09/09 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
the covers get brittle with sun and age. i just replaced both of mine. my repairs did not last.
tommy wilson
1996 kountrystar dp
spartan mountainmaster chassis
