RV.Net Open Roads Forum: Looking for advice on towing a Toad
 > Looking for advice on towing a Toad
Class C Motorhomes Related Tips
willtravel2
texas
Posted: 11/14/09 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
I just replaced the pressure relief valve and now I'm not getting any water coming out of any of my faucets? I replaced the valve and screwed in the tank plug where I drained it then went to turn on the water pump to get water flowing in to the water heater and no water is coming out? I can hear the water pump running but no water. This is weird because it worked yesterday when I was messing with the old pressure valve. Is there something I need to do to get the water running or could my water pump be bad. My coachmen is a 2001 so maybe the water pump has gone bad. Thanks
enblethen
Moses Lake, WA USA
Good Sam RV Club
Posted: 11/14/09 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Open hot water faucet, allow water to fill water heater and purge air out of tank. It will take about 6 gallons or so.
Bud
Suzuki XL7 pushing Pace Arrow
willtravel2
texas
Posted: 11/18/09 06:55am Link  |  Quote  |  Print  |  Notify Moderator
Problem Solved! I bought a new temp relief valve, put it in the water heater and now I get HOT water without it leaking. Thanks all
hohenwald48
Hohenwald, TN
Posted: 11/18/09 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Sometimes pressure valves leak because as the water heats it expands. In a closed system, like in an RV, there is nowhere for the expansion to go so it goes out the valve. Installing an expansion tank in the cold water line will give the expanding water a place to go and will also stop the pulsating of the water pump.
2001 Monaco Knight
2004 Dutchmen Dorado
1999 Jeep Wrangler
100% Solar Powered Home
When seconds count, the police are only minutes away.
ron.dittmer
I Will Be Dancing With The Stars On 1/23
Posted: 11/19/09 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
An expansion tank like I installed works great for a more consistent water pressure & temperature, which is most appreciated when showering. As hohenwald48 says, it also eliminates the irritating rapid groaning of the water pump.
My wife & I are "Dancing With The Stars" for PADS on 1/23
Read about it in my "View Profile"
Then scroll down to "More About Me"
