Two guys, out in the wilderness, winter camping. Sorry, but all I can think about is the scene in Planes Trains and Automobiles where John Candy Tells Steve Martin his hands are between two pillows and Martin howls "Those aren't pillows!!" Remember to run around asking "How bout dem Bears!!!" Pleasant dreams.
Battery: Don't you need the battery in order for the furnace to work? If so and you don't have your battery hooked up and you try to use the furnace and it doesn't work, it could be cause it needs the battery.
Susan I
2008 McKenzie Starwood 32 FKD TT
Hensley & Prodigy Brake Controller
03 Dodge 3500 Quad HO Diesel DRW 4:10
Fulltiming, On the road somewhere.
forty4san wrote: Battery: Don't you need the battery in order for the furnace to work? If so and you don't have your battery hooked up and you try to use the furnace and it doesn't work, it could be cause it needs the battery.
The furnace will run off the converter if the rig is plugged into shore power. It will provide the 12VDC.
