RV.Net Open Roads Forum: Tech Issues: glad I got the 6 volt batteries
 > glad I got the 6 volt batteries
Tech Issues Related Tips
stevenkd
Simsbury, CT
Posted: 11/12/09 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Near the end of the year I changed to two 6 volt Sam's Club GC2 batteries. They worked well when we were out on Columbus day weekend, temps went to the 30's and the batteries kept us going all night, charged them during the day with a generator. After returning home they have been plugged into shore power for a couple of weeks. After removing the batteries on Saturday, they still register 12.9 volts 6 days later without any charger on them. I have a battery minder that I am going to use for the winter, I am going to wait for a while to see how long they stay charged with no load on them.
09FLSTC
Out West
Posted: 11/12/09 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Good for you, you will love them. Just make sure you have a 3-stage converter charger if you plan to run them down like that and have the ability to bring them back up faster if you boon dock. Actually, if you already do, there is no need for a maintainer if you can connnect your camper to power when you store it.
BENT ARROW
CO.
Posted: 11/12/09 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
I would think after 3 or 4 months they might show 12.2 volts.
Bent Arrow
99 PACE ARROW 35'
Chevy 4x4
4 Wheel Pop-Up
S10 Blazer ZR-2
Golden_HVAC
Fulltime, CA, USA
Posted: 11/12/09 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
HI,
I was really impressed with my 9 year old Trojan T-105. So I replaced them expecting the new set to work better. It did not, I was a bit disappointed, but know that the new set will last more than 10 years if I keep the RV that long. I gave the old batteries to a friend, and he might still be using them!
I use hydrocaps, they recycle the waste hydrogen and oxygen leaving the batteries into water, so I only need a little bit each year.
I think you can charge your batteries about twice during the winter, and they will stay pretty full while resting.
If you really want to see the batteries last while out dry camping, get a Olympic Catalytic Heater. It will keep the trailer toasty warm down to about 30F outside without needing the furnace at all until below that temp. Then running the furnace a few minutes an hour, I can blow hot air into the corners of my 30' RV and the basement to keep it all at around 70.
I have a 1992 6,000 Btu catalytic heater, it is still good. I keep a dust cover on it, as well as keep it in the closet until needed. It has a leg kit and quick disconnect to the low pressure gas line below the oven..
Good Luck,
Fred.
fla-gypsy
North Florida
Posted: 11/12/09 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
Nice move, this is a mod I need to make!
Camping Photos
mynetdude
Grants Pass, OR
Posted: 11/13/09 12:02am Link  |  Quote  |  Print  |  Notify Moderator
I'll never use catalytic heaters again, not after what I witnessed using the one here that came with mine, gonna be uninstalling it and selling it too.
Wherever I happen to park
Posted: 11/13/09 09:42am Link  |  Quote  |  Print  |  Notify Moderator
I will ask.. What happened with your Cat-Heater (I know a few reasons to avoid them too but I won't go into that)
As for the batteires:
Trojan's often last 9-10-11 years
Interstates 7-8-9
I'm not sure Trojan's are worth the additional cost
Sam's and Costco's are made by the folks who make Interstates.
smkettner
Good Sam RV Club
Posted: 11/13/09 09:56am Link  |  Quote  |  Print  |  Notify Moderator
What charger are you using? Or what is the converter?
Glad they are working for you
RJsfishin
Winston Or.
Posted: 11/13/09 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Well, ya better do it quick, before the Olycat haters find their way over here, and convince you that them thar Olycats will kill ya if you don't leave all the windows 1/2 open
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
RJsfishin
Winston Or.
Posted: 11/13/09 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Dam, they got over here before I even got that typed !
Them Olycat haters don't waste no time. But, I ain't seen a Olycat hater yet that ever had one, but the first one mite be developing above
