RV.Net Open Roads Forum: Tire Size and Rating for a 28 Foot Class C Motorhome
 > Tire Size and Rating for a 28 Foot Class C Motorhome
Class C Motorhomes Related Tips
forcedfun46
Ohio
Posted: 11/13/09 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a used 1989 Mobil Travel 28 foot RV. I just found out that it needs new tires. This is the first time that I have had to buy tires. I'm not sure what "rating" of tires to buy. Do I buy "D" rating. Very confusing. Ok, very very confusing.
Anyone have any advise?
pauldub
North of Seattle
Posted: 11/13/09 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Probably load range E, but what is on it now?
hwybnb
Posted: 11/13/09 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
Somewhere on your MH there should be a sticker that states what size tires it requires. That is the best way to be sure you get the right ones.
If you want to start from scratch, first get the thing weighed, with separate weights for each axle. Then download the specification charts from Michelin or which ever tire company you are going with and see what load range is required to carry your weight. You will also need to know what size rims you have (diameter and width) and how much pressure they are rated for.
It will be a lot easier just to find the sticker.
* This post was edited 11/13/09 06:04pm by hwybnb *
Dakzuki
Carnation, Wa, USA
Posted: 11/13/09 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Look on the inside of the driver's door.
95 Chinook Premier
AZGarfield
Phoenix AZ
Posted: 11/13/09 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Read the information off the tires on there now and your tire dealer should be able to tell you what the rating is for those. Also you can contact the manufacturer of the MH.
Garfield, Wife & 13 Year Old Future MLB Player
2004 Gulf Stream Conquest 6725 27' Class C
forcedfun46
Ohio
Posted: 11/13/09 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone for all the information about tires and sizes.
We take our first real road trip next Thursday. I'm assuming that my new tires will be able to take me where ever we need to go!
skipnchar
Topeka Kansas USA
Posted: 11/13/09 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Door post will tell you tire size to handle the GVWR of your vehicle.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
tatest
Oklahoma
Posted: 11/14/09 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
That vintage, the Gross Vehicle Weight Rating would have been in the range that used Load Range D tires. You need at least that rating, and Load Range E will also work, and might be easier to find, depending on the size.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
fisher60
Plant City, Florida
Good Sam RV Club
Posted: 11/14/09 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
My 28' came with "D" and I had multiple failures. I moved up to "E". Weigh the rig. If it's even close to max I'd go with the "E".
'01 Dutchman Express 28A, Master Tow, '06 Tuscon, '05 Honda VTX 1300
Good Sam Life Member
