RV.Net Open Roads Forum: General RVing Issues: Electrical Question
 > Electrical Question
General RVing Issues Related Tips
hwybnb
Posted: 11/15/09 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
You need an INVERTER, not a converter as some have told you. An inverter transforms DC battery power to AC. For watching TV an inverter rated at 300 watts or more should work.
Do not try to run an inverter that size off of a cigarette lighter as some have suggested. A lighter socket is not designed to supply that much power. You will need to wire the inverter directly to the batteries.
We typically watch television for three or four hours an evening on battery power with no problem, but we have 220 amp-hour battery capacity.
Homer
Northwest Ohio
Posted: 11/15/09 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
12V to the antenna from the booster is just the way they have the antenna wired so it will work in all configurations. I would not count on a big inverter plugged into a cigarette lighter. Larger inverters should be hard wired.
smkettner
Good Sam RV Club
Posted: 11/15/09 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
I use this pure sine wave inverter to power the 120v tv circuit:
http://www.boatandrvaccessories.com/GP-SW300-12
I connected it behind the distribution panel. 12v connected to the main battery feed. 120v connected with this automatic transfer switch:
http://www.boatandrvaccessories.com/ITS-30R.htm
Remote switch turns it on as needed and if left on it draws only 250 milliamps (1/4 amp) at no load.
Wherever I happen to park
Posted: 11/16/09 10:45am Link  |  Quote  |  Print  |  Notify Moderator
I too will say this: You expect a 12 volt battery to run a 120 volt TV? I don't
At least not without an inverter.
I have a xantrex Prosine 2.0.. it runs the TVs and related electronics, The Microwave and the GFCI "loop" (Recepticals) which includes the baths, kitchen, dining room and outside outlet. The remaining outlets including the bedroom. and the 20 amp outlet I put in for an electric heater... DEAD w/o shore or generator power.
K3WE
Missouri
Posted: 11/16/09 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of folks have hinted, but not come out and said- The 12V system is pretty limited- a little lighting, water pump, a little bit of TV (if you have a 12V TV or inverter), and one or two days of running the furnace.
Now, some folks (like me) go for that kind of camping from time to time- use some commmon sense, limit your electricity and the battery can last for several days.(OR you can do the generator thing)
If the 110V outlets were working, and you plugged in much of anything, you will suck the battery down very quickly.
