RV.Net Open Roads Forum: Travel Trailers: Batteries boiling/Cougar
 > Batteries boiling/Cougar
Travel Trailers Related Tips
freewayrandy
'Old Hangtown', Ca
Posted: 11/16/09 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Hi All,
Posting this for a friend, on his Cougar TT, when hooked to shore power he notices his batts begin to boil. He's already cooked one set and now wondering what the heck is going on. Is his converter/charger toast or is there some adjustments/settings to change somewhere?
Thanks.
'03 GMC 2500HD, SLT, D/A, Rancho 9000X, Fabtech, Visions, Michelin XDE/MS 245/70R19.5, Fuzion 322 Touring Edition II, Polaris Sportsman 500, Honda Foreman 450ES
pianotuna
Regina, SK, Canada
Good Sam RV Club
Posted: 11/16/09 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Hi freewayrandy,
For anyone to help your friend the make and model of the converter, and the type and number of batteries would be a first step.
It does sound as if something is either out of adjustment on the charging rate or that the converter may have had a failure of some kind.
freewayrandy wrote:
Hi All,
Thanks.
Regards, Don
Kustom Koach Class C 28'5" 256 watts solar, 875 amp hours in two battery banks 12 volt batteries 2500 watt inverter.
smkettner
Good Sam RV Club
Posted: 11/16/09 09:35am Link  |  Quote  |  Print  |  Notify Moderator
What is the battery voltage before he plugs in and again after they start boiling? I assume he has checked the water is at the proper level.
Pond Jumper
North Texas
Posted: 11/16/09 10:51am Link  |  Quote  |  Print  |  Notify Moderator
I had a bad converter that caused the same problem. I would have that checked first.
PJ
skipnchar
Topeka Kansas USA
Posted: 11/16/09 11:12am Link  |  Quote  |  Print  |  Notify Moderator
It's probably just the nature of his particular converter. If it's not a multi stage charger then the best cure would be to upgrade to a better converter/charger.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
mtdew999
Backwoods, Oregon
Posted: 11/16/09 11:24am Link  |  Quote  |  Print  |  Notify Moderator
My converter won't shut off the charge switch automatically. I put in a disconnect to the battery and keep the battery on a minder. My unit is old but aside from that, works perfect.
freewayrandy
'Old Hangtown', Ca
Posted: 11/17/09 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all for your responses. Now to find it in the coach and get a replacement.
