RV.Net Open Roads Forum: Travel Trailers: Furnace power draw
 > Furnace power draw
Travel Trailers Related Tips
Capehorny
Posted: 11/16/09 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Hello all, went camping this weekend and needed to run my furnace off the battery power, wasn't able to get to shore power. Everything went fine but I got to wondering how much drain that puts on the battery. Does it simply draw strictly when lighting the pilot and running the fan when it cycles on? It's a 2006 Jayco Jay Flight. Just curious, any opinions would be appreciated.
skipnchar
Topeka Kansas USA
Posted: 11/16/09 11:03am Link  |  Quote  |  Print  |  Notify Moderator
In most RVs the furnace is the largest single draw on your batteries. Yes it does use power to ignite the burner and to operate the thermostat but the BIGGEST draw is running the blower.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
btd35
Spokane, WA
Posted: 11/16/09 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Yes the furnace draws a significant amount of power. If you are running a dual 12 volt battery setup, most of the time it will just make it through the night if your system is strong, and it isn't too cold. I wouldn't leave your pigtail to your vehicle connected over night to add the vehicle battery to the mix as I have heard some do. They wake up in the morning, and can't start the vehicle because it has been drawn down too far by the furnace.
Tom & Beth
05,Grand Junction 35TMS
99, Dodge 3500 Dually.
canoe on top
Denver, CO, US
Posted: 11/16/09 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
If you look at the bochure for the furnace it should tell you how many amps the blower draws. From that you can figure about how long it will run on the battery capacity you have. Of course, it is off and on so that makes it more difficult to figure. How well insulated your TT is and how cold it is make a big difference.
skipnchar
Topeka Kansas USA
Posted: 11/16/09 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
If you tow with a Ford or newer Toyota, a relay will protect the vehicle battery unless the ignition is in the "on" position. You won't run down the battery but won't get any battery BOOST by staying connected either.
Chuck&Gail
In the Colorado Mountains
Posted: 11/16/09 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
We figure one nite per battery when running furnace.
FYI not all Fords disconnect the TV battery from the TT. My Bronco II did not. IMO if unsure, disconnect TV to TT cable when parked, ESPECIALLY if nobody else is around. TV's are darn hard to push, and automatic transmissions do not jump start well anyway, if that is what you have.
My ML320 does not disconnect when turned off, so we unplug cable.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
califRVers
Santa Rosa, California
Posted: 11/16/09 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
This may seem like a silly question, but here it goes, does it draw even more battery power when using the high fan setting over the low fan setting?
Tim and Julie
California RV'ers Blog
2010 Outback 260FL 31'9" GVWR 7800 - Atwood 3500 - Eaz Lift Elite
2006 F150 4x2 Supercrew Lariat 5.4L Triton V8 3:55 LS 139" WB 19,000K Miles
GCVWR 13500 - Prodigy - Flowmaster - K&N Filter
tomdrobin
Perry, MI
Posted: 11/16/09 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
Yes.
BlueDuramax
Aurora, Oregon
Posted: 11/16/09 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
Furnaces in modern RV's are the worst design flaw they have. They are noisy inefficient current drawing devices. Someday maybe someone will design a good one. Of course they could go back to the great ones we had in our old Aristocrat trailer, a wall heater with actual flames in it and no fan.
[b]2004 2500HD Chev EX/LT Duramax/Allison, Prodigy controller, Old style Reese dual cam hitch, Curt Magnum 5 receiver hitch, 2007 KOMFORT 277TS, Honda 2000.
Note: Due to invalid formatting, all formatting has been ignored.
smkettner
Good Sam RV Club
Posted: 11/16/09 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
My furnace fan does not change with the fan speed switch. The High/Low just changes the air conditioner fan speed. So on mine I believe the furnace fan draws the same power on high or low.
