Jack&Kay
Santa Rosa, Ca
I canceled the order for the White Plastic shower head and made a new order for the Chrome model. It is also on back order. I don't like that CW doesn't tell you that until you actually order something. I guess you can always cancel the order after you already placed it. Won't get until mid May now unless if comes in early, but that's okay. They had a great price on the chrome one, a lot better than even Amazon.
Jack & Kay
2007 Tiffin Allegro 28DA
Ford Chassis V-10
Blue Ox Tow Bar to a 94 Honda Accord
FMCA #F341229
mikeintn
Lenoir City TN
IAMICHABOD wrote: I also installed the Oxygenics shower head with the holder it is needed because of the extra weight BUT it only comes with one hole for one screw I found that isn't enough so we drilled another hole and attached it that way It really needs two plus some sealer just to make it leak proof.
If you unscrew the holder clip (it won't fall out) the other hole is behind it
Mike, Cindy, Chris and Spunky the Cocker Spaniel
1998 32 ft Tiffin Allegro
Ford F53 with 460 V8
Onan 5500 Watt Generator
Master Tow 80THD tow dolly
2009 Mini Cooper S Toad
Jack&Kay
Santa Rosa, Ca
When I got home yesterday, my neighbor and her 4 year old grandson brought over a big box that was my shower head. Early delivery. Only took about 10 minutes to install. Can't wait to use it now. What a spray! I did buy the wand holder too.
searfoss
East Stroudsburg PA USA
How are the bugs? I hear they can be bad if the wind is coming off the bay and not the ocean.
Poconos Pennsylvania
2007 Gulf Stream Gulf Breeze 23TRS
2004 Dodge Ram 1500 Quad Cab
4X2 5.7 hemi 3.55 rear
RIP Mike, we miss you so much
RaenMark
We picked up our brushed nickel finish from the local CW. Installed it before out trip and just used it this morning, it's great. Actually feels like a shower and not the dribble from the old one. I'm sold and DW liked it too.
Rae & Mark
Bountiful, UT
1999 Fleetwood American Tradition 40
Just got it and learning about it as we go!
mema/poppop
florida
Does it have a shut off switch?
Lady Fitzgerald
Tempe, AZ, USA, Earth
EMD360 wrote: ...But I bought a shut off for it for $5 because the shower control does not shut it off completely, it continues to drip.
The shut off is designed to drip so the water temperature will stay constant. Otherwise, hot water can either cool down in the pipes while shut off, giving you a cold initial blast when you turn it back on, or the hot water might back up into the cold water pipes, giving you a scalding blast when you turn it back on.
Jeannie
Gotago2
Ocala Florida
I also installed the Oxygenics shower head and got shut off valve from Lowes. Just remember to point shower away from you when you turn on shut off valve. DW says she now like taking shower in MH.
Norm
2011 Itasca Sunstar 35F (35')Ford V-10, pulling 03 Nissan Frontier.
nremtp143
Georgia
I put a $4 push on/off adapter from Home Depot on my mine. Really easy to turn on and off with really soapy hands. Most all have standard threads. Plus, it fits in the original holder that came on the camper.
2012 Sandpiper 365SAQ, Goodyear G614s, TST TPMS
2010 F350 DRW 6.4L 4x4, Edge CTS, B&W Companion, Viair 10007 air system, Firestone Ride-Rites,Flo-Pro cold air pipe
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
