Waverunner
Lakeland Fl.
I am having some leaking in the roof of my moho in my sig.Have done the eternabond tape but still have a small leak in the rear.After reading about liquid roof I went to order some and was told my roof needed a special primer and several other steps.Has any one else run into this problem.Thanks in advance for the help.
Dave
Airstream-Landyacht 30
2000 Jeep Wrangler
ScottG
Bothell Wa.
I didn't know they ever used Filon for roofs. Are you sure that's what it is?
Scott, Grace and Wesly
H0NDA eu2000i
Bumpyroad
Virginia
I "assume" that the leaks are at seams, not thru the "filon".
bumpy
Waverunner
Lakeland Fl.
I called Airstream and that is what they told me.It is a very thin Fiberglass.For some reason FRP sticks in my mind also,not sure why.
Waverunner
Lakeland Fl.
I would assume so also.Whenever you cut that many holes in a roof it spells trouble.I was hopeing the liquid roof would solve my problems.But that seems to be turning into a major job.Airstream dealer said 2 days at $110.00 an hour jeez!
Two Jayhawks
lenexa ks
ScottG wrote: I didn't know they ever used Filon for roofs. Are you sure that's what it is?
Safari used it too that's what I have.
2002 Safari Zanzibar
CAT C12 455/1550
Allison 4000
Saturn Vue w/ReadyBrake
FMCA# 390819
Livin Good
On The Road
Another reason I don't care for Fiberglass Roofs....
LVJ58
Las Vegas, Nevada
You may want to try this:
http://www.campingworld.com/shopping/pro........uct/dicor-self-leveling-lap-sealant/5737
Good luck
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
Waverunner
Lakeland Fl.
Thanks for all of your help.I am still weighing the options.
Dave
J-Rooster
Port Orchard, Wa. / Lake Havasu City, Az.
My daughter had a roof leak in her 5ver same place as yours. And she bought some self leveling lap sealer from Camping World as mentioned by another previous poster and it was easy to work with and worked very well no more leaks!
