RV.Net Open Roads Forum: Class A Motorhomes: spot free rinse
 > spot free rinse
viajante
Plumas Lake, CA, (near Yuba City) USA
Posted: 02/22/12 07:10am Link  |  Print  |  Notify Moderator
Is it really just a piece of PVC with fittings on each end ? I'm thinking there must be more to it than that.
Dave & Brenda
Shadow (Sheltie), and Zoe (Shih Tzu)Faithful Companions
2008 Itasca Sunrise 35L
Ed9824v
Agua Dulce, Calif. 70 mi N.E. of Los Angeles
Posted: 02/22/12 07:49am Link  |  Print  |  Notify Moderator
seems as if it would need some fine screen at each end as well
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
pkunk
Questa, NM
Posted: 02/22/12 09:40am Link  |  Print  |  Notify Moderator
Sent PM-waiting for a reply
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
decan9
Oceanside, CA
Posted: 02/22/12 10:28am Link  |  Print  |  Notify Moderator
the fine sprayer on the end keeps the granules in!
Bonnie and me and Casey makes three!
Staying warm in Southern California
FMCA #402157
W9NCR
viajante
Posted: 03/05/12 09:26am Link  |  Print  |  Notify Moderator
It seems pretty straight forward. However, it would be very helpful if someone could give a brief "how to", including parts needed.
Thanks much.
footz
Sacramento
Posted: 07/06/12 09:11pm Link  |  Print  |  Notify Moderator
Does anyone have the instructions on how to make the water softener device?
Thanks
FIRE UP
Lake Havasu City AZ
Posted: 07/06/12 11:03pm Link  |  Print  |  Notify Moderator
Gang,
That "Water stick" looks about as simple as it gets. I think I could build one in about 20 minutes if I had all the parts in front of me. I think I'll take this project on. It looks like about 24" of 2", reduced to 1.5" and reduced again to 1" and finally an adapter for a female garden hose swivel end, which I already have. And on the business end, the same reducers are in place only a male garden hose fitting is on that end. I might put some sort of screen in there to keep the granules in, heck that's just some window screen maybe. What a cool experiment.
Scott
Scott and Karla
SDFD RETIRED
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
SCVJeff
Santa Clarita, CA.
Posted: 07/07/12 04:17am Link  |  Print  |  Notify Moderator
I have one of these and it works pretty well. You HAVE to contain the resin beads, otherwise you will blow the entire tube clean in under 30sec. The trick is the fancy screens that they have in there that became unavailable for awhile and caused the company to cease production... Looks like they got through that.
I would like to know what the 2 different resins are to see if they can be found cheaper in bulk. One is the standard soft water rechargeable resin, the other is not, but because they are mixed together, you need to replace them both.
Jeff - WA6EQU
wla7
Warren, Ohio
Posted: 07/07/12 06:39am Link  |  Print  |  Notify Moderator
Why not use (purchase) one of the portable water softners. I have one and it works great. I use it primarily for soft water in the coach but can easily use it to rinse the coach too.
Wla
2014 American Eagle 45 A
2015 Jeep Wrangler
00 BUCK
NE Ohio
Posted: 07/07/12 07:20am Link  |  Print  |  Notify Moderator
FIRE UP wrote:
Gang,
Scott
Not quite that easy
see below you need a water in ( the long red pipe) to bubble water through the resin , then need a screened water out ( short red tube)
and it must stand on end if constructed this way and filled only 3/4 to 6/8's of the way with resin beads
2011 Newmar - VENTANA -- with COMFORT DRIVE ">
2011 Jeep Wrangler Unlimited Sahara
Blue Ox Aventa LX Tow bar w/ Roadmaster adapters
AirForce One brake system
Life Member GOOD SAM Club
FMCA Member
If your not the lead dog
the view never changes
 > spot free rinse
