When i place water into toilet after use, the water does not stay and leaks out. Is this a gasket/seat issue? is this an easy fix? or do i need to call the rv guy?
Get a good toilet brush and simple brush around the opening in the bottom of the toilet (valve) and flush with water. More than likely something is caught in the rubber preventing a good seal. A microscopic bit of "you know" can cause a gap in the seal. A simple brush down the hole does wonders. Then a little lubricant (even a couple drops of vegetable oil) will help soften and seal the rubber and not damage anything. I'd avoid any lubricant with petroleum as petroleum can deteriorate the rubber seal.
If that does not help, then repeat a couple times. I bet you'll be fine. But if not, then you'll want to take stronger action, like replacing the seal, or even the toilet.
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
It might be some toilet paper stuck in the seal, and letting water out, air up into the bathroom.
WHen my RV was 6 years old, just before the extended warranty expired, I had to have the seal replaced, and that fixed mine for several years. Now I have to pull up on the handle to keep the valve shut all the way, so it will hold water. I guess there is something causing it to stick a little open, or might be a worn gasket that is getting in the way from it closing all the way.
If pulling up the handle works, then this can work for a few years, but ultimately you will need to replace the valve.
Quote:Tie a string around anything you use to clean with and tie the other end around your wrist.
Anything you drop accidentally will cause more problems than a leaking bowl.
I was going to mention the same thing.Good advice for sure.
If you need a new seal try here: Toilet seal
They make them, so they have others than just the link. I have used them and they work fine. Easy replacement.
I had the problem with my Thetford Aurora. After trying all the usual things with no success, I replaced the upper mechanism today. No more leaking bowl. Should be good for another 10 years.
I have used vinegar for several years to clean the mineral's from the Arizona water that builds up on the rubber seal. pour alittle in the bowel and let it sit.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
