RV.Net Open Roads Forum: Fifth-Wheels: Gree Rooftop Air Conditioners
 > Gree Rooftop Air Conditioners
overthehillbill
Patterson, Ca.
Posted: 03/21/12 08:48pm Link  |  Print  |  Notify Moderator
Anybody seen one of these?
Clicky
I am considering a second A/C and wondering if anyone on the forum has one.
Bill
'08 Cedar Creek 32TK, 35'9", 13,990#
'01 F-250,Lariat, 7.3L, SC, Auto, LB, JW Towmaster Tranny, 6.0L Tranny cooler, DP custom tunes, 4" Turbo back exhaust, Auto Meter Gauges, Firestone Air Bags. '07 Headlights and Grille, Prodigy P-3.
rv2go
Fulltime (Knoxville, TN).... or someplace else
Posted: 03/21/12 10:05pm Link  |  Print  |  Notify Moderator
I just hope the Gree unit is better than some of the other junk we get from China.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
www.rv2go.us
I'm here #4335
Travel Photos
Deetour
Washington
Posted: 03/21/12 10:55pm Link  |  Print  |  Notify Moderator
Gree is a fairly large company building all types of AC systems from little RV units to huge commercial AC's & chillers.. I'd sure wouldn't hesitate to try them.
Here's a little blurb from their homepage.
As a specialized air conditioning manufacturer, Gree is presenting advanced and high quality airconditioning products to global consumers. With six (6) manufacturing plants based respectively in Zhuhai (headquarters), Chongqing, Hefei, Brazil, Pakistan and Vietnam, Gree employs more than 40,000 employees, working on both residential and commercial air conditioners of 20 varieties, 400 series, 7000 models and nearly 3000 technical patents; all to satisfy different demands by different consumers. The GMV digital VRF system, centrifugal type water chiller and sine wave D.C. inverter driven air conditioner filled the absence in production of high-tech products among Chinese enterprises. Being the model that developed from a "made-in-China" enterprise to "created-in-China" enterprise, Gree has gained wide reputation in the international industry.
Ex-Tech
West
Posted: 03/21/12 11:24pm Link  |  Print  |  Notify Moderator
Why not go with Coleman or Dometic and know you are gettimg a unit that has a dealer network that will work on them, perform warranty if needed and stock parts?
RoyB
King George, VA
Posted: 03/22/12 07:48am Link  |  Print  |  Notify Moderator
Just a bit off subject but I always thought about using a swamp cooler type air conditoning which are available for RV's as the second a/c. That might work out for some camping off the power grid situations. You certainly couldnt use the two different type of air conditoners together however with one putting in wet air and the other one pulling out wet air haha...
The only thing I dont think I could live with would be the 2nd air conditioner mounted directly over the sleeping bed setup. Seems like that would be rather close. IN my setup I can reach up and almost touch the ceiling when laying in bed.
Alot of folks have them however so must not be too bad...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
webslave
Clearville, PA
Posted: 03/22/12 09:41am Link  |  Print  |  Notify Moderator
The only thing that would concern me a bit about the Gree...the height. If, as on my Cougar, the second A/C mounting point is at the highest point of the trailer (front bedroom vent), then their height, at 14.7" could be an issue and would most likely put you over 13'... I went with a Briskair to stay under that 13' mark.
Just a thought...
My 2 cents, your mileage may vary...
Don
Bronwyn
3 Cats - Coco, J-Lo and Ragamuffin
2011 Keystone Cougar 318SAB
2011 Ram 2500 Longhorn CTD HO
Built in brake controller and exhaust brake
Tri Glide TrailAir Pinbox with a B&W Companion Hitch
