L2C
Placentia ca
Does anyone know If this is a good rv?
HiPro
My brother has owned that coach since new. They are happy with it although it has no bedroom slide. Has big Cat diesel power.
UltraKen
Ohio
Safari made high-quality coaches. Used solid wood cabinetry. With proper maintenance should be a good choice.
You should use a checklist, either the one in my signature or one googled. You also should have a mechanical inspection at a good diesel shop.
UltraKen
Ex - 1968 Ultra Van
NOW - 1996 Safari Sahara 35' - Model 3530 - Cat 300
Pictures of my Coach
A $93 Rear Camera System
My take on replacing tires
Used MH Checklist
Toad: Dodge Grand Caravan on Tow Dolly or 1981 Vespa on utility trailer
John&Joey
Some Location
A couple of years ago we had neighbors with one. They loved it, and had nothing but good things to say. He did rechip it to get more power as I remember.
Two Jayhawks
lenexa ks
I agree the build quality was above average. Over all I'm happy with my 2002 but I don't know how it compares to a 2000.
2002 Safari Zanzibar
CAT C12 455/1550
Allison 4000
Saturn Vue w/ReadyBrake
FMCA# 390819
L2C
Placentia ca
It's priced at 33500. It's under nada value. Haven't checked it out yet but I'm gonna need new tires and the windows are double pane and it looks like the rubber on inside was shrinking up. Probably gonna need new windows too. Does anyone know if it's very expensive to replace the windows
MrWizard
Traveling
AFAIK .. the rubber is only for rain gasket and trim
it has no effect on the sealed double pane
if the windows are not clouded, then you don't need new windows,
the trim is a lot cheaper than new windows
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
