RV.Net Open Roads Forum: Fifth-Wheels: JT Strongarm question
 > JT Strongarm question
Timothy
Wisconsin
Posted: 04/17/12 07:53pm Link  |  Print  |  Notify Moderator
The landing jacks on my trailer have the pins facing the front instead of the sides. Does anybody know if I can install the JT's with this configuration?
Tim & Cindy
2010 Canyon Trail 35FLFT
2001 Chevy Silverado 2500HD Crew Cab
8.1 Allison
www.gsowners.com
m&d kelly
Redlands, CA, USA
Posted: 04/17/12 08:04pm Link  |  Print  |  Notify Moderator
The pin placement for the landing jacks should not be an issue. I am not at my 5er but I believe the bolt is below any pin holes.
Mike & Dava
2007 Sierra Classic 2500 HD Duramax/Allison 4X4 Crewcab, Super Springs
2005 Carriage Compass 30RLS, MOR/ryde suspension & Pinbox, Onan 3600LP
Huskey 16K EZ Roller, DigiTrac
Dwight205
Terre Haute,IN
Posted: 04/17/12 08:11pm Link  |  Print  |  Notify Moderator
Just installed mine, my brother in law just ordered his set. He said his holes are with the camper length(mine are across) Just turn the U bracket 90 deg. The U tabs will face each other between the legs.We are planning on doing this on his rig this wknd.
tvman44
Southwest Louisiana
Posted: 04/18/12 05:54am Link  |  Print  |  Notify Moderator
Should not be a problem, but call JT to be sure.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Mile High
Denver, CO
Posted: 04/18/12 07:17am Link  |  Print  |  Notify Moderator
They work either way. Mine was like yours so I used the U-bracket struts for the cross frame, and the other struts to run down from the main frame to connect to the U-Bracket.
There should also be a long chrome nut that you can use as a handle to raise your landing gear.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
Timothy
Wisconsin
Posted: 04/18/12 11:18am Link  |  Print  |  Notify Moderator
Thanks everyone, guess I'll get a set!
fj12ryder
Platte City, MO
Posted: 04/18/12 06:30pm Link  |  Print  |  Notify Moderator
I second the suggestion to call them if you're unsure. They are super to work with. I received the wrong size T-bolt and called them, they had one at my house within just a couple of days. Great after sale service.
Howard and Peggy
"Don't Panic"
dezolen
Ontario
Posted: 04/18/12 08:02pm Link  |  Print  |  Notify Moderator
Might want to check this one out.
http://www.steadyfast.com/Purchase.html
overthehillbill
Patterson, Ca.
Posted: 04/18/12 08:33pm Link  |  Print  |  Notify Moderator
I did and it appears to be a simpler system. It works as advertised on my Cedar Creek. Just my .02.
Bill
'08 Cedar Creek 32TK, 35'9", 13,990#
'01 F-250,Lariat, 7.3L, SC, Auto, LB, JW Towmaster Tranny, 6.0L Tranny cooler, DP custom tunes, 4" Turbo back exhaust, Auto Meter Gauges, Firestone Air Bags. '07 Headlights and Grille, Prodigy P-3.
