RV.Net Open Roads Forum: Truck Campers: New Truck camper questions
 > New Truck camper questions
billyray50
Dallas
Posted: 04/23/12 08:33am Link  |  Print  |  Notify Moderator
Hello,
Wife and took delivery on 2012 Adventurer 86 FB and noticed after our 1150 trip back from dealer that there is a slightly concaved ripple on rear overhang. Sent pics to service warrenty dept and also went to a local rv dealer and rv tech said that sometimes its normal?? Huh??. Also have some some surface rust on Three of the electric Happijacs. Whats the best way to paint them? Thanks.
http://s907.photobucket.com/albums/ac280/billyray50/
mkirsch
Rochester, NY
Posted: 04/23/12 10:51am Link  |  Print  |  Notify Moderator
You're talking about a smooth flat white surface here, the worst possible scenario for body work. Every imperfection is going to stick out like a sore thumb. VERY difficult to get a perfect smooth surface, especially at the price point campers are built to (yes, even the fancy expensive high-end models). Bet you'll find some sort of ripple or burble on ANY new camper you look at.
Document the ripple and monitor it. If it gets worse then put more pressure on the company to fix it under warranty.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
kerry4951
East Central Pennsylvania
Posted: 04/23/12 11:01am Link  |  Print  |  Notify Moderator
I have a few areas on mine where you can see slightly raised areas in the filon. They occur where the plywood seams are located. Its definitely not delamination as they were there early on when the TC was brand new. They have never gotten any worse. Its a situation where the factory just didnt hide the seams as well as they maybe could of. Its probably not a whole lot to worry about.
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
Super_Dave
Sacramento, CA
Posted: 04/23/12 11:51am Link  |  Print  |  Notify Moderator
The condition of the jacks in the pictures would REALLY worry me.
Truck: 2006 Dodge 3500 Dually
Camper: 2007 Eagle Cap 850
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
narcodog
Georgia
Posted: 04/23/12 12:16pm Link  |  Print  |  Notify Moderator
I would not worry about the jack rust. Just spray it with silicon and let it go. Your instruction manual show tell you to spray the jacks.
billyray50
Dallas
Posted: 04/23/12 02:55pm Link  |  Print  |  Notify Moderator
Thanks everyone. I sent pictures to service warranty manager at Adventurer so it is documented and wash and waxed the jacks.
the tc life
colbert wa.
Posted: 04/23/12 03:28pm Link  |  Print  |  Notify Moderator
wow, those new jacks are showing a couple years wear already. whats with the interior pics of screw hole damage or what ever it is? this was a new unit not a repo right?
as far as jacks....mine are a couple years old now and are starting to show some rust. i need to spray them with some lube. you can always call happijack and ask about them too.
2010 adventurer 810ws
1999 c3500 dually 12' flatbed
THE TC LIFE
billyray50
Dallas
Posted: 04/23/12 04:19pm Link  |  Print  |  Notify Moderator
It is a 2012 Adventurer 86 FB model new..pics of inside was the window treatment fell on to the dinette table on trip home from dealer...never seen anything like it. had a 1996 and 2004 truck camper before and that never happened. local rv dealer fixed it under warranty. Like to paint some of jack surface rust..any suggestions?
the tc life
colbert wa.
Posted: 04/23/12 04:47pm Link  |  Print  |  Notify Moderator
i dont have any ideas on painting the inner tube. id imagine it would take paint like anything else though. ive seen some posts on here about using bed liner on the outside tube.
at least they fixed some things for you right away. thats good.
billyray50
Dallas
Posted: 04/23/12 09:32pm Link  |  Print  |  Notify Moderator
Yes they have been helpful so far with any issues. I was thinking just applying some rusto leum high heat black spray on rust spots. So how do you like your Adventurer 810ws??
