RV.Net Open Roads Forum: Older Diesel vs Newer Gas - Which to buy?
Search only in Tow Vehicles
 > Older Diesel vs Newer Gas - Which to buy?
LoveTwoCamp
Arcola, Pa
Posted: 04/24/12 06:59am Link  |  Print  |  Notify Moderator
Family member is looking at Ford E350, 12/15 passenger vans. Mostly for family use, with some light towing (utility trailer, popup). They cannot afford a newer vehicle, which also means they cannot afford costly repairs or downtime for repairs.
In general, which should be a better vehicle to pick (both being reasonably maintained and in good cosmetic shape): A) a 2002, 7.3 diesel with 235,000 miles, used for towing(road miles), at $7500; or B), a 2006, 5.4 gas with 100,000 miles, no hitch, at $9500?
Are there enough benefits to the diesel engine package to pick the older van?
I have offered my advise, but would like to get some outside opinions.
Thanks in advance.
og
2000 Holiday Rambler AlumiLite 28'
2004 Silverado 2500HD, 4X4, Crew Cab, Duramax/Allison
Reese Dual Cam
Two 6 Volt Batteries with Control Switch
Prodigy Controller
ib516
Up here!
Posted: 04/24/12 07:04am Link  |  Print  |  Notify Moderator
I'd go with the gasser as long as they don't plan on towing heavy. The 135,000 less miles on everything else (trans, suspension) will save some money in the long run IMO.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
carringb
Corvallis, OR
Posted: 04/24/12 08:04am Link  |  Print  |  Notify Moderator
I like the 7.3L. That said.... owning an older diesel isn't for somebody who isn't decently familiar with them. The 7.3 certainly has a quirks. It requires a special coolant additive, and if that hasn't been used cavitation can get so bad the engine will hydrolock. The Camshaft Position Sensor is notorious for suddenly causing a complete loss of engine operation. The 7.3L also goes through periodic flow plugs, and occasionally injectors. Expect to pay for 3-6 hours of labor each time that happens, unless he is a DIY person.
Also, the 7.3L has an appetite for stock Torque Converters, so if that hasn't been upgraded yet, it's only a matter of time.
The 5.4L is a decent engine, for your friend's, is probably a better choice, because there isn't much that goes wrong on those motors that'll leave you stranded. It'll sound like it's working harder, and won't have a much pull off the line, and will be shifting through the gears on hills. But it'll do it reliably.
So why would I pick the 7.3L over the 5.4L for my own use? Because this:
http://www.youtube.com/watch?v=d54Ss6puVVg
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
DKean
Mays Landing NJ.
Posted: 04/24/12 08:05am Link  |  Print  |  Notify Moderator
My vote goes to the 2006 5.4 gas. If it doesn't have a hitch then I guess it doesn't have a trans cooler either. If they tow lite like you mentioned they should be OK. But keep the cooler in mind just in case. Heat is the biggest killer of transmissions.
2006 F350 CC LB 6.0 diesel dually. 2006 Cedar Creek fifth wheel. Six 6 volt golf cart batteries,3000 watt inverter. Mountain Master generator in truck bed remote start. Automatic satellite dish.Air suspension on truck and trailer.Level up with 6 jacks RC
blt2ski
Kirkland, Wa
Posted: 04/24/12 07:56am Link  |  Print  |  Notify Moderator
ALong with, but do not quote me, the newer 5.4 may have the same ponies altho a bit less in the torque dept. So overall, pulling etc may be on par to slightly less with the 5.4. You may also have a 5 sp auto, again, do not quote me vs a 4 sp with the diesel. A lot of things could be better overall with the new one vs the older one.
marty
05 Chev CC D/A LS Dooley
3 Single axle utility trailers
Check RV.Net Blogs at: blog.rv.net
Clattertruck
Centennial Colorado
Posted: 04/24/12 07:24am Link  |  Print  |  Notify Moderator
Ditto on the gasser. The 7.3 was a great engine, but chassis may be pretty well used up. The trans of that era was not the best.
Clattertruck
2008 SD F450 Pickup PSD 6.4L CC 4X4 DRW, Lariat Auto trans 4.30 LS, 2008 Snowriver 108 truck camper. 2013 Lance TT 1885, Toyota 4Runner 2011.
danojeno
Corona, CA
Posted: 04/24/12 10:06pm Link  |  Print  |  Notify Moderator
Only way I would even consider that diesel is if I could score it for $5k. Even then, I would be shoveling money away for a new one when something went wrong.
2006 Chevy 2500HD 8.1 4x4 CCSB
2012 Eclipse Stellar 28SBG, Spring Over Axle
jerem0621
Sequatchie, TN
Posted: 04/24/12 10:18pm Link  |  Print  |  Notify Moderator
gas gas gas
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
Gale Hawkins
Murray, KY
Posted: 04/24/12 09:11pm Link  |  Print  |  Notify Moderator
Gas is about the only option if on a budget.
If you are pulling a 10 ton track hoe then gas is not so ideal.
VintageRacer
Dundas, Ontario
Posted: 04/24/12 08:27am Link  |  Print  |  Notify Moderator
A friend of mine has the e350 extended van with the 7.3, he hates it in comparison to his F350 with 7.3. Says there is no comparison. I'd go for the newer version. Also, remember that those vans have a relatively higher accident and fatality record, some areas are banning them for school use. I suspect that they are a little too big for the chassis, they are very easy to overload. The light gas engine will make it a better balanced vehicle, and a lot lighter.
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
