As the title asks, I have been searching the web for the factory specs for this make/model,no luck.
Is there a site that has honest numbers? Better yet,is there any owners of this model that have had their unit weighed?
The reason I ask is we just traded in our Sprinter Bunkhouse for this unit and the advertised dry weight was 9600 lbs.
Looking at the tag on the coach tonight GVWR=14,086 lbs..I hope this means dry weight plus cargo.
For what its worth, our 2001 F-250 7-3 PSD pulled this thing wonderfully..
2005 Cardinal 29 TSLX
2001 Ford F-250 CC 4x4 7.3 PSD Long Bed,Firestone Airbags,4" Exhaust,Isspro Gauges,DP-Tuner,Reese 16K Select
donn0128 wrote: If you bought it, you might as well start looking for a dually now. There is no way you have enough truck in a F250 to pull a 14K fiver.
My Cedar Creek 34CKTS has a GVWR of 13,750 and I normally travel at 13,500. My pin weight is 3000+/-.
My Cedar Creek 32TK GVWR 13,990 pin weight on the old 2001 7dot3 is 2000#. Just went across the scales and I'm 60# under combined vehicle weight. Still pulls and stops great. I am not grossed out on the trailer and the truck is 2WD super cab.
Bill
'08 Cedar Creek 32TK, 35'9", 13,990#
'01 F-250,Lariat, 7.3L, SC, Auto, LB, JW Towmaster Tranny, 6.0L Tranny cooler, DP custom tunes, 4" Turbo back exhaust, Auto Meter Gauges, Firestone Air Bags. '07 Headlights and Grille, Prodigy P-3.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
