RV.Net Open Roads Forum: Truck Campers: How Did You Balance Your 19.5 Wheels?
 > How Did You Balance Your 19.5 Wheels?
Bigfootchevy
Bancroft, Ontario, Canada
Posted: 05/01/12 08:50pm Link  |  Print  |  Notify Moderator
I ordered my 19.5 tires and rims from Ricksons. You pay extra to have them balanced. Mine work great.
Paul
Pete_k
Stantonville Tn
Posted: 05/03/12 06:20am Link  |  Print  |  Notify Moderator
Just a heads up, I had the place that sold me the Toyo's. Try to tell me I had a wheel out of round. I asked them how the old set of tires I came in with were not doing what the new ones were doing? Found out they had 8.5 oz on that one. After getting mad, they changed that one out for me. But took a few months, You can bet the next set I will be sure to get them where I have the 30 day ride deal. And trade out until there right. Still had 2 tires with over 6 oz of lead on them. And they were match-mounted and then road-force tested, Poor guy worked for 3 1/2 hours on them. But then again for what I paid they should have been swapping out 2 others.
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
Photog101
Garden City, Michigan
Posted: 05/03/12 06:31am Link  |  Print  |  Notify Moderator
campguy30/40:
Rickson sent me tires and rims, in December, that were balanced with weights and equal. I'll never use Equal again. This is the second set of tires that I have used that junk. The powder got wet at some point and had clumped in the tires. Last set I had dismounted and cleaned out the tires and rims. They were then remounted and the balancing beads were installed. I will be doing the same thing to these Rickson supplied tires and rims.
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
saltamontes
la, ca
Posted: 05/03/12 10:39am Link  |  Print  |  Notify Moderator
i use the dynabeads also (larger bead size). No prob, scooping them out and reusing when buying new tires. 3 of my toyos needed maybe 1oz balancing weights, 4th needed 5 oz. Lined up the yellow dot on tire w/ the valve stem, but no other special balancing done. I removed the stick-on weights the 1st week and wear has been even over ~45k life of tire w/ no obvious vibration.
i am happy w/ dynabeads and plan on reusing them
07 f350 srw shortbed 4x4
06 Northern-Lite 8'11" Q
JumboJet
Tontitown Arkansas
Posted: 05/03/12 11:43am Link  |  Print  |  Notify Moderator
I just broke down 4 tires that had Equal in them. I don't know how they looked going down the road, but the Equal had clumped and was sticking to the sidewalls. I used a vacuum with upholstery brush to remove them. Didn't need the Equal anyhow.
jimh425
Western WA
Posted: 05/03/12 12:37pm Link  |  Print  |  Notify Moderator
Equal is supposed to stick to the sidewalls and "clump".
'06 F350 Lariat Supercab SRW, 6.0 PSD 4x4 Long Bed, Intake Elbow, Walker Big Truck Muffler. '06 Host Rainer 950 Double Slide, Fastguns. Firestone Air Bags, Rancho 9000s, Vision 19.5s with Hankook DH-01 245s, Energy Suspension bump stops.
JumboJet
Tontitown Arkansas
Posted: 05/03/12 03:41pm Link  |  Print  |  Notify Moderator
Did not know that. I like the Centramatics better anyhow.
Photog101
Posted: 05/03/12 10:38pm Link  |  Print  |  Notify Moderator
Both sets of tires that I had with Equal, did not balance worth a hoot. I removed it and replaced it with Tech Plus Beads and never had better balanced tires.
