RV.Net Open Roads Forum: to chip or not to chip DURAMAX engine?
 > to chip or not to chip DURAMAX engine?
larry barnhart
wenatchee. wa usa
Posted: 05/05/12 06:32pm Link  |  Print  |  Notify Moderator
The reason we bought the duramax is because it has enough power stock to pull our 35 ft alpenlite.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
christopherglenn
a little over an hour from Yosemite
Posted: 05/05/12 07:14pm Link  |  Print  |  Notify Moderator
EFI-LIVE can increase the timing, which will help mpg's with minimal risk of breaking things, A small 5-10% fuel increase can also be done with minimal risk - the 4-5 and 5-6 shifts are where most people get in trouble.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
jim87vette
Arizona
Posted: 05/05/12 07:22pm Link  |  Print  |  Notify Moderator
Your numbers are good I wouldnt mess with it.But if you must get EFI.
08 GMC 3500 Dually Duramax
96 Chevy 2500 6.5
05 Yamaha Rhino
04 Gearbox 335FS 5er 14k wet
BobsYourUncle
Surrey, BC Canada
Posted: 05/05/12 11:10pm Link  |  Print  |  Notify Moderator
Don't think I would mess with it.
I had an '03 LB7 and currently have an '07 Classic LBZ.
The difference between the LB7 and the LBZ driving under exactly the same circumstances, driving habits etc. is nearly exactly 2MPG difference.
I run all the time with a big rack and toolboxes, which weighs around 2000 pounds and is as aerodynamic as a brick. So based on that, my '03 LB7 got around 14 MPG, my LBZ gets around 12, not towing.
Towing, I don't see that big of a difference because I am always driving with at least a ton on the back of my truck. Towing, on both trucks, my economy goes south about 15 to 20%.
And yes, my foot is a bit heavy, always has been. I do like the feeling of passing things going up mountain hills towing, with the cruise control on.
The D-max has plenty of power right out of the box. I see no need to chip it unless you want to roast the tires off the line and be the first guy to the next light. I seriously doubt you will see any increase in MPG. It is all relative. More ponies equals more fuel burned under most all circumstances.
Duramax / Allison
Fire Red
95 Sportsmen 25.5' TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Bob's Trucks
Check Out My Rebuild Project
Project Feedback
09FLSTC
Out West
Posted: 05/06/12 12:57am Link  |  Print  |  Notify Moderator
Total waste of time, money and brain cells IMO. I've chipped two trucks and won't again. Oh but I wanted the towing power, fuel milage and planned to keep the truck forever! Good luck with that decision, really.
edatlanta
Panama City Beach, FL
Posted: 05/06/12 06:39am Link  |  Print  |  Notify Moderator
I have a 2006 LBZ and I tow heavier than you and consistently get 12 mpg plus/minus a half or so. I never tow over 60 mph. I wouldn't touch it with any programmer.
Ed
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, TTT/Schefenacker Towing Mirrors, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
buzzard616
Medicine Hat, Ab, Canada
Posted: 05/06/12 07:58pm Link  |  Print  |  Notify Moderator
Any engine comes from the factory with a finite amount of grunt. Adding cams, turbos, chips and so on lets you use more grunt at a time but when it's used up, it's done.
Same as eating with a bigger spoon.
Stu & Jackie Metcalfe
2000 Salem 27FKSS
2008 Sierra 2500 HD gasser
ktmrfs
Portland, Oregon
Posted: 05/06/12 10:40pm Link  |  Print  |  Notify Moderator
a bit of warning. starting with MY 2006, GM can check the ECM to see if a non factory program was ever installed in the truck. even if you remove it, and put back the factory program, the checksum will be stored showing a modified program. can result in a denied warranty claim and a void in power train warranty. In some cases the dealer will need to do the check and send verification to GM showing no modified program was ever installed before they will authorize a warranty power train repair. If your still under your 10 year power train warranty with mileage it's something to consider.
If you go with EFI live, you can buy a new ECM and keep the old ECM with factory programing to swap back in so it doesn't show a non OEM program.
2011 Keystone Outback 295RE
2004.5 Silverado 4x4 CC/SB Duramax/Allison
Hamops
Oshawa, ON, CA
Posted: 05/08/12 08:57am Link  |  Print  |  Notify Moderator
I'm getting about the same results for our LBZ and all I do is put the truck in "D", turn on "T/H and set the cruise for a 100 klicks and drive.
Cheers
Helen & George VE3INB and Max (Bichon Frise)
2006 Silverado 2500HD D/A, Isspro Gauges, Linex, Westin Nerf Bars, Fold-A-Cover
2006 Cruiser CF30SK.
Reese 16K Slider, Bedsaver, Prodigy Controller, Rearview Camera, JT StrongArms
ktmrfs
Portland, Oregon
Posted: 05/08/12 09:53am Link  |  Print  |  Notify Moderator
my 04.5LLY gives similar mileage. heavy mountains and I'm in the 10 range, dead flat 12+, average is usually slightly less than 12 hand calculated. I'm towing about 9000lbs TT. And usually keep it under 60.
