RV.Net Open Roads Forum: Truck Campers: Tie down question
 > Tie down question
seraphim
Ohio
Posted: 05/05/12 06:54pm Link  |  Print  |  Notify Moderator
We just purchased a truck, but have not chosen the camper yet. Are there any potential problems with me buying a set of heavy duty Torklift tie downs before identifying the camper I intend to use? The truck is a 3500 diesel dually, and it appears the only two factors in choosing the system are truck characteristics and weight of the camper.
2012 GMC 3500HD Crew Cab LB 4x4 DRW with Duramax 6.6 diesel
2013 Palomino Maverick 2902. "Panserbjorn
"I am an armored bear..."
narcodog
Georgia
Posted: 05/05/12 07:17pm Link  |  Print  |  Notify Moderator
You buy the tie downs for the truck then you can use them on all modern campers.
halibutman214
Oregon
Posted: 05/05/12 07:37pm Link  |  Print  |  Notify Moderator
No.
2008 Dodge Ram 6.7 Laramie SRW SB
2012 Keystone Passport 26BHWE
2009 Lance 830 with Tent foldout
20' North River Seahawk Boat
2005 Honda VTX1300
Bigfootchevy
Bancroft, Ontario, Canada
Posted: 05/05/12 09:42pm Link  |  Print  |  Notify Moderator
Yes buy your torklift tie downs to fit your truck. They will work on your camper.
Paul
seraphim
Ohio
Posted: 05/06/12 10:12am Link  |  Print  |  Notify Moderator
Thank you all. I thought that to be the case, but wanted no surprises lol. Figured if I installed the tie downs now, I'd be ready when I found the right camper.
elkhornsun
Monterey
Posted: 05/08/12 10:40pm Link  |  Print  |  Notify Moderator
If you know the likely brand of camper you can get the truck pre-wired for the connection. Makes it a lot easier if you buy from a private party.
Hey there
Pendergrass, GA
Posted: 05/09/12 12:29am Link  |  Print  |  Notify Moderator
What if the seller has a set of tiedowns to go with the camper? Then you will have two sets.
Kurt
2001 Silverado 3500 DRW CC LB 6.0
1993 Lance Squire Lite 150 (8'6")
2001 Fleetwood Caribou 11J (11'6")
wintersun
Monterey
Posted: 05/10/12 12:51pm Link  |  Print  |  Notify Moderator
If the seller has tiedowns how practical is it to buy the camper and then install the tiedowns and then drive back to pick up the camper? Most of the used campers where I live are a 4-8 hour drive each way and I am not about to do that twice.
And that is assuming that the seller has the same model truck as I do so that they will fit my truck and with Torklift tiedowns even the ones that were supposed to fit my 2011 truck required a lot of cutting and trimming to get them to bolt on properly to the frame. I needed a bench vise, power hack saw, and a right angle grinder to get the Torklift tiedowns mounted on my Chevy.
jimh425
Western WA
Posted: 05/10/12 01:56pm Link  |  Print  |  Notify Moderator
You should probably also think about taking your tailgate off in advance, too.
'06 F350 Lariat Supercab SRW, 6.0 PSD 4x4 Long Bed, Intake Elbow, Walker Big Truck Muffler. '06 Host Rainer 950 Double Slide, Fastguns. Firestone Air Bags, Rancho 9000s, Vision 19.5s with Hankook DH-01 245s, Energy Suspension bump stops.
 > Tie down question
