buc1980
houston tx
I am tired to replace the plumbing vent cap every 2-3 years.I like to find a metal cap(just the cap) SS if possible.Anybody find a place to sell them
2011 Ford F350 DRW,2005 Kountry Star 35ft,Breaksmart controller(not install I use Ford controler ),Equa-Flex.6 points LIPPERD Level-up.
tandkj
Full timer
Question, why are you replacing them so often? Is it the product or are you hitting them on something?
Tis another fine day to serve in and for the glory of the Corps. Every day is a holiday and every meal a feast.
08 Camelot
07 Ranger Toad
One Golden Retriever at the Rainbow Bridge and a new one traveling with us.
recycler
michigan
try Vintage Trailer supply they show them on their site..they also carry 14" metal vents if you dodn't want to be replacing rotted plastic all the time
1968 franklin 11fk
93 d250 cummins
99 f550
STICKS55
TEXAS HILL COUNTRY
Yes, the sun will " do in" the non uv stable plastics in short order,, simple solution I've starting doing,,,,, whenever I replace one of those items like a vent cap, I now give a coat of the new "fusion" paint by Krylon,, adds years to the life, blocks the uv rays. Same for my propane tank cover when it become non cleanable, works great
jk
buc1980
houston tx
Like everything else which come from China, the caps too, they junk and it broke fast.Before years ago I don't have any problems with them.They made in USA.
arizonakid
Stow Mass. USA
buc1980 wrote: I am tired to replace the plumbing vent cap every 2-3 years.I like to find a metal cap(just the cap) SS if possible.Anybody find a place to sell them
I found a metal one in the trash... after a little modification...
The plastic cap had disintegrated, and I temporarily put a tin can over the remainder.
Then I thought.... why not add a little larger can over it, drill some holes, pop rivet the tins together, and for good measure, fix it to the vent with two screws....
No, it's not SS but should last a few years.
Trlrboy
Rockwall, Texas
BRAVO! Sauerkraut and tuna fish as a plumbing vent cap. What could be more suitable?
2010 Montana 3400RL
Chevy 2500HD Duramax
PHOTOLINK
gmctoyman
Lake Livingston, Texas
Nice fix, but I've wondered why we even need them on RV's, never had one on a house.
Dave W. AKA "Toyman"
KE5GOH - On 146.52
RV's ? What RV's ???
Apache Pop-up
Classic GMC Motorhome
07 Leisure Travel Sprinter
Do Boats Count ?
gotsmart
Aberdeen, WA
Because a holding tank is a closed system, in which sewage gases can build up. Without a vent stack to provide an escape route for the sewage gases the only other place for the gases to escape is right up the neck of the toilet when you step on the flush handle. The vent stack prevents the toilet from burping a nasty fart bubble back into the coach when you flush.
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
jetboater454
Camping or home
Mine have been gone for years.No problems without them.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
