carjocky
Northwest Ohio
I have a 2009 Dodge Ram 1500 and wondering about helper springs. Has anyone installed them and how do you like them?
Thanks,
Jon
Ohio
2012 Keystone Bullet Premier 29RTPR
2009 Dodge Ram Crew Cab 1500 5.7 Hemi
nascarnutz
We had air on our last TV ('04 Ram 1500) and loved them. Prior RV was a TC and it was nice to be able to fill them when we needed to and bring them back down for daily driving. Taking the "wait and see" approach on new TV as we have upgraded to a TT now and have not yet had the chance to fully load both - that'll be next month
Bob & Lori (BNL)
2012 Tracer 230FBS (Cupcake)
2012 Ram 1500 ST Hemi 5.7 (Smoke)
Why didn't we do this sooner ?!?!?
carjocky
Northwest Ohio
Ok. So I looked at the WD hitch that I got from the RV dealer.
Blue Ox SwayPro Weight Distribution System w Sway Control - Trunnion Bar - 8,000 lbs GTW, 550 - 750 lbs TW
My TT dry tongue weight is 735 is what the factory lists. I assume that this is most if not all the problem I am having? Shouldnt they have given me the Blue Ox SwayPro Weight Distribution System w Sway Control - Trunnion Bar - 10,000 lbs GTW, 1,000 lbs?
With the trailer/truck loaded, dual battery, propane etc the 750+ max is not doing the job.
Thoughts?
tvman44
Southwest Louisiana
I prefer air bags.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
shakyjay
California
I put SuperSprings on my Dodge several years ago. Made a huge improvement as far as ride, handling, and load carrying. The big surprise to me was that the improvement in ride while unloaded. I can't really address towing vs not as the only way I have really towed anything substantial with it was with them installed. I have loaded both the Dodge 1500 and my GMC 3/4 equally with approx. 2000 lbs in the bed. The Dodge handled just as well as the 3/4 ton albeit without the power of the diesel.
2007 Rockwood 8315SS
2004 GMC 2500HD Crew Cab Duramax Diesel
1999 Dodge 1500 5.9L Gas
MO_Trout_Bum
Missouri
You should have 1000lb trunions at least. Probably should really be 1200's for a 10000 lb gross weight TT.
2004 Silverado 2500HD Ext, Duramax LLY, 4WD, 3.73
2012 Keystone Cougar 327RES
Bonefish
Midland, TX
We had SuperSprings installed on our 2000 F250 last year. Wish I had done it sooner. Made a huge difference in towing and ride.
Super Springs
ib516
Up here!
Check out http://www.timbren.com/.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
carjocky
Northwest Ohio
Went to the dealer and just picked up the 1000-1500ob tunions from them. He asked me "are you sure that is what you want?" like I was making a mistake. Now he has me guessing my decision... But I just cant see how it is not what I need at this point.
735 tongue weight listed from Keystone
110 Lb hitch from Blue Ox.
150 Propane and 2 batteries
100 - 200 lb? Gear in front camper storage.
1145 lbs with nothing in truck. I guess I will have to hook it up tomorrow after work to see what happens
fly-swatter
Alberta, Canada
I've got Timbren rubber springs on my 08 Dodge 1500 and really like them. Install them and forget about them with no effect on the ride while not loaded.
