RV.Net Open Roads Forum: Tech Issues: Surge protector question
 > Surge protector question
Stars101
NY
Posted: 05/15/12 11:06am Link  |  Print  |  Notify Moderator
We have a TT. I've never used a surge protector, but this is our first new TT. The others were all older and not worth much. What could happen if we don't use one? I understand for a high end Diesel pusher or a FW. But ours is less than $10,000. Or could it damage the fridge, AC, etc?
parkdep
Lapeer Michgan USA
Posted: 05/15/12 11:13am Link  |  Print  |  Notify Moderator
Here is a article that may help you on surge guards, I wont leave home without one: Surge Guards
2oldman
Winchester WA
Posted: 05/15/12 11:14am Link  |  Print  |  Notify Moderator
If you wish to read them I have all kinds of links to previous discussions on this often-asked question.
Desert Captain
Tucson
Posted: 05/15/12 11:18am Link  |  Print  |  Notify Moderator
About half of the folks here say it will never be a problem and the other half feel you can't live without one. Yes a power surge can destroy just about anything plugged in and AC's and refrigeration systems can get pricey to replace. I guess the biggest risk are the older RV parks and CG's where the electrical system is ancient and suspect. For the record I finally broke down and bought a surge protector and an AC meter to monitor voltage. The SP was about $100 and the meter another $12. A full EMS system that will also protect you from low voltage runs around $350. Whatever you buy protect it from thieves as these things tend to walk away. I use a short length of chain that fits around the pedestal but can't be lifted up and off.
smkettner
Posted: 05/15/12 11:25am Link  |  Print  |  Notify Moderator
If you check polarity and ground with a $5 tester and periodically check voltage you have covered most of what the protectors do. When you get bored with checking in a few years then get the protector or not.
675 watts solar
M GO BLUE
Southgate, MI
Posted: 05/15/12 11:30am Link  |  Print  |  Notify Moderator
Voltage regulators, voltage testers, etc. etc. do nothing for you unless you are watching them 24/7 and enven then you could be screwed...
The price of a good multi-function is ~ $250 (30A) to $350 (50A)...now compare that to having to replace your converter, inverter (if so equipped), water heater, TV's, refrigerator, microwave, stereo, AC and any other electronic equipment you have should "bad" power get into your RV...
I won'y plug into anything without first pluggin into my surge protector and then plugging the surge protector into the outlet...
The smart choice would be to invest the money and get a good multi-function surge protector...
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
Stars101
NY
Posted: 05/15/12 11:59am Link  |  Print  |  Notify Moderator
Thanks everyone. I know that this has been covered extensively, but I find the RV.net search engine wonky. It never gives me the info that I am looking for.
I think I'll get one. My husband is getting really crabby about all my "research" on this forum. Mostly b/c it leads to more work for him! As he has stated (quite LOUDLY), "I have enough hobbies of my own that I can't get to. I don't need to add your TT as another one. Stop reading that #@!& RV.net forum before you drive me crazy!"
CincyGus
Cincinnati
Posted: 05/15/12 12:23pm Link  |  Print  |  Notify Moderator
Just let him know that your reading here, may very well save you enough money or find better ways to do things that make it easier for both of you. That is, as long as you stay out of the modification forum ;-)
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
smkettner
Posted: 05/15/12 12:57pm Link  |  Print  |  Notify Moderator
Portable is easy install.
vic46
Red Deer, Alberta, Canada
Posted: 05/15/12 01:42pm Link  |  Print  |  Notify Moderator
M GO BLUE
I wouldn't plug into anything without first pluggin into my surge protector and then plugging the surge protector into the outlet...
I think you would be wise to reverse your process. V/R first to the pedestal and let it do it's thing, then plug the RV into the V/R.
As far as monitoring a volt metre, when you see a spike or brown, it has already gone through your electrical system and quite likely the damage is already done!
Vic
Lack of common sense is the greatest mental illness known to mankind.
