RV.Net Open Roads Forum: Tech Issues: new microwave
 > new microwave
peteandpatty01
East Greenbush, NY
Posted: 05/18/12 12:36pm Link  |  Print  |  Notify Moderator
The micro wave in the RV has stoped working, so a new one is in order. Can I purchase any microwave that will fit into the space of the old one or do I need to purchas one made for RV use?
Thanks
Peter
2oldman
Winchester WA
Posted: 05/18/12 12:37pm Link  |  Print  |  Notify Moderator
Peter
no
SWD
Land of Living Skies
Posted: 05/18/12 12:56pm Link  |  Print  |  Notify Moderator
Just go to Walmart and pick up a MW that will fit in the existing space. I did that last year. You may have to be creative and make some retaining brackets or re-use some of the hardware to hold the mw in place.
Pangaea Ron
Anacortes, WA, USA
Posted: 05/18/12 12:50pm Link  |  Print  |  Notify Moderator
My microwave also quit working last week. Mine is:
Sharp Model R-1880LST over the range convection microwave with integral exhaust fan Serial No. 112961 manufactured in 2007.
It seems that there is a fuse that can be replaced (with some caution). I have a local appliance store investigating the issue.
We were using it (interior MH temperature was ~95F) for about 20 minutes, with a 5 minute rest, then another 8 minutes, and "bzzt". The circuit to the MW is fine?
2008 Itasca SunCruiser 35L
2000 Jeep Grand Cherokee Laredo
TechWriter
On The Road
Posted: 05/18/12 01:10pm Link  |  Print  |  Notify Moderator
Can I purchase any microwave that will fit into the space of the old one or do I need to purchase one made for RV use?
New micro will not only have to fit dimensionally, but also be properly sized electrically. For example, older RVs may use a 15A circuit for a microwave. If you attach a 20A micro to a 15A circuit, be prepared to reset the circuit breaker.
Look at micro models online. On many appliance sites, you'll be able to check the dimensions & power requirements.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
- Solar -- Solar Power
- Water -- Water Filtration
- Blog -- www.rvSeniorMoments.com
RV Volunteers CONUS
Full-Time - Park City, Kentucky
Posted: 05/18/12 01:49pm Link  |  Print  |  Notify Moderator
Our sharp convection/micro quit a couple years ago.
Do a search using the brand, model#, you may find an exact match.
We found our exact match online at Walmart.com....Still working today.
2006 Allegro 34WA, Workhorse W20
2013 Chevrolet Sonic LTZ
2009 Blue Ox Aventa LX
2009 Break Buddy
Swagman XC-2
Roadmaster Dual 2" Drop Receiver
VOLCONUS
RV Volunteers Trip Journal
sharker6
fulltime KY, NC, FL, MA, TN
Posted: 05/18/12 01:50pm Link  |  Print  |  Notify Moderator
There's not much to a microwave and it's almost always the slow-blow fuse when it stops working. I would try that first.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
Pangaea Ron
Anacortes, WA, USA
Posted: 05/18/12 01:51pm Link  |  Print  |  Notify Moderator
My local appliance store/repairman said that it is a good thing that the MW quit working entirely, because it is probably just a fuse. One is for temperature, and the other for power.
I'll remove it tonight and take it to the shop tomorrow to hopefully have the fuses checked/replaced.
sharker6
Posted: 05/18/12 01:54pm Link  |  Print  |  Notify Moderator
There's probably an access panel on the inside so you don't need to take it out of the hole to get to the fuse.
Pangaea Ron
Anacortes, WA, USA
Posted: 05/18/12 02:00pm Link  |  Print  |  Notify Moderator
I'll look for an access panel which is probably on the top rather than inside (I'll look closer for that), but since it's built in with a wood cabinet top, I'll probably need to remove the front face trim (at least at the top edge), remove a couple of screws, and lift it off the wall hook? Some apparently tilt forward for access, and some need to be completely removed??
I think that I'm looking for a few pinched fingers in the process?
Thanks for the hints.
 > new microwave
