RV.Net Open Roads Forum: Tech Issues: engin battery
 > engin battery
hogbob
S.F CA.
Posted: 05/20/12 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Hello
I have a 2011 winnabago adventurer.The engin battery keeps going dead after afew days.Even though i am hooked to shore power.It is A FORD
.THANKYOU FOR ANY HELP
KENNY
mena661
Posted: 05/20/12 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
hogbob wrote:
Hello
KENNY
I don't know about your exact model but some motorhomes don't charge the chassis battery from shore power. Those that do have a relay somewhere that allows this to happen. I couldn't tell you where that relay is though.
Trojan L16 6V's 740 Amp-hours
Son of Norway
Denver, Colorado
Posted: 05/20/12 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
Have the battery checked at an auto shop to make sure it's still good. Also, If you have an ammeter, I would get a measurement on the drain from your battery. It seems to me that you have an electrical problem that you need to track down.
Miles
Miles and Darcey
1989 Holiday Rambler Crown Imperial
Denver, CO
Retiredblade
Western, Pa
Posted: 05/20/12 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
hogbob wrote:
Hello
KENNY
It should not go dead in a few days, when I am parked I turn the master switch off for the chassis battery. Mine does not get charged while hooked to shore power. So I got a Xantrex digital echo charger which takes amps (trickle) from coach batteries and keeps the chassis battery charged, if the coach batteries fall below 13 amps it cuts off.
I think your might have a bad battery. Mine are getting old and need replaced also.
fischer
livingston, tx
Posted: 05/20/12 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
My south wind with ford chassis charges with engine and plugged in with battery control center.
My original battery lasted 7 years ? Ford has a 60 month warranty. Things that could use up the engine battery is your dash radio, dash fans stairs lights left on,putting out slides without running engine. Check the water level in the cells. Do you have a smart monitor?
2005 Southwind 32vs F53 Retired
2006 Jeep Liberty 4x4
Blue ox Tow Bar
fischer
livingston, tx
Posted: 05/20/12 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
smkettner
Posted: 05/20/12 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.lslproducts.com/TLSPage.html
675 watts solar
RoyB
King George, VA
Posted: 05/20/12 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
I have accidently run my truck NON-DEEP CYCLE battery down a couple of times and it always seems like when that happens they just arent any good after that. My truck computer electronics that is always on will run my truck start battery down in about 4-5 days to the point I cant start the truck.
I definately need to buy another truck start battery I reckon. In my situation I have my 2KW generator always sitting in the tailgate side of my truck bed so I just pull out my B&D portable charger and hit the battery for 15-minutes worth of charge and it usually starts right up.
I'm the only guy sitting in a crowded Walmart parking lot with a extension cord coming out of my generator and the hood up on the truck hehe... At least I get to go back home without standing around with my jumper cables in my hands with the "help me" look....
Always got a PLAN-B
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
ryanallie1
Magalia, Calif
Posted: 05/21/12 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Hi All.
Rather than put up with this at all, why don't you just fix the problem. And make the engine Battery get charged while on Shore Power, or runnning your Generator.
We also have a Ford F-53 Chasis, and all of our Batteries get charged no matter what the sorce is.
Its such an easy fix. Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
Janss
Sedona, AZ
Posted: 05/28/12 01:07am Link  |  Quote  |  Print  |  Notify Moderator
What is that easy fix? My engine battery also does not get charged from generator or shore power.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
 > engin battery
