RV.Net Open Roads Forum: Fifth-Wheels: Honda Generators
 > Honda Generators
Page of 5
jauguston
Bellingham, WA
Posted: 05/29/12 08:12am Link  |  Quote  |  Print  |  Notify Moderator
The 3000w Honda Handi generator is closer in sound level to a open frame construction generator than a EU series. That is one reason why it is cheaper than a EU3000i.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
robert@honda
Atlanta
Posted: 05/29/12 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Jim
To clarify, the EU3000is (electric start, larger fuel tank, quietest Honda generator sold today, 200cc engine, mostly steel) is $2329.95 MSRP, and the EU3000i Handi (pull start, smaller tank, louder, 160cc engine, magnesium(!) and plastic materials) is $2599.95 MSRP.
Like a lot of things, it's what pros and cons matter most to your situation. EU3000is customers appreciate the electric start, large fuel tank, quiet operation. They dislike the weight (134 lbs) and the battery is a maintenance item when the unit is not used regularly. Wheel kits are a cost-up accessory.
The Handi customer likes the light weight (76 lbs), built in wheels and carry handle, offset lifting handles, convenience light on control panel. They dislike the higher price, louder noise level, and shorter run time (smaller fuel tank).
I guess that's why the pair of EU2000i generators in parallel is preferred choice of many. Not only do you get the extra 1,000 watts, they are lighter, quieter, and priced about the same as a standard EU3000is.
-Robert@Honda
Caveat: I work for Honda, but the preceding was my opinion alone.
bushman512003
wallaceburg,ontario,canada
Posted: 05/29/12 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
woodywoodguy wrote:
The honda eu3000i will run everything, except a/c and microwave at the same time. Make sure your tank is bigger then 1.5 because running the a/c all night will only last 6 hrs, unless you don't mind getting up in the middle of the night to fill it up.
I run the air all night and have never ran out of gas think it is some thing to do with the Oil I use in it I have never ran out of fuel fill it every morning again before going to bed I use the econo mode when useing it do You?Bush
Keystone 5er Model Cougar 276 RLS ,and all the toys.Enjoying camping,friends, fire. LOL. life is good..John,Jeannette,..From Canada the Queen's Country..Member of IRV2.Com. The Bushman EH!
avvidclif1
Posted: 05/29/12 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Ever think about the night-time temperature differential between Canada and the Southern US???
Clif & Millie
Ozzie half a dog tall and 2 dogs long
2009 Ford F350 SRW CC Lariat 6.4 Diesel
2011 Crossroads Cruiser CF285RL Patriot Edition
bushman512003
Posted: 05/30/12 01:40am Link  |  Quote  |  Print  |  Notify Moderator
Yes I know the difference is hot and humid We camp in the south Mississippi or south west Yuma area BLM from early Dec. till April so now think it may be the oil or some other reason My old big red runs longer maby I have a different jet set up in the carb.......all I know it is real easy on gas and starts easy and I need no exrta fuel tank to run the air all night or all day....this unit was a bought in Canada one the specks are different I was told....but thats what the Honda shop said when I bought it. CSA for importing to Canada is a little more stringent than the USA for many things as Electric codes, gas emishions etc.some what like California...CSA and UWL are not the same standards at all ...
robert@honda
Atlanta
Posted: 05/30/12 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Canadian-spec Honda EU2000i generators do not have the parallel outlets due to CSA rules. USA-spec Honda EU2000i units do have parallel outlets. Labels on Canadian-spec models are in English and French (or use icons/drawings) while USA-spec models are in full USA-legalese :-) Otherwise, I do think the units are the same, including emissions (both exhaust and evaporative) certification levels.
bushman512003
Posted: 05/31/12 01:21am Link  |  Quote  |  Print  |  Notify Moderator
WOW as We tell some thing about a 3000 some one tells about a 2000 what is the matter with sticking to the size again do not tell Me what I have is not different than a 2000 because I know what I have is..... Big,red,heavy,elect.start,and runs all night and thats all I know also they are not the same as USA 3000
Crabbypatty
Long Island, New York
Posted: 05/31/12 04:41am Link  |  Quote  |  Print  |  Notify Moderator
I had the same issue. I finally purchased the eu3000 as it was easier for my wife to just turn the key. I am glad I did as when we dry camp with the 3 gallong gas tank, we can go 3-4 days of dry camping before I need to refuel. The 2000's do not have the fuel range and you would need to by extra tanks to run them longer. If its a hot night it will run all night on one tank for the a/c with reserves. To make it easier on the genny I installed a "hard start kit" for the a/c This is nothing ore than a larger capacitor that when its charged kicks the a/c on instantly. I have now had the eu3000 for 7 years along with two trojan t-125 6volt industrial batteries and its a good dry camp package. Happy trails!
John, Lisa & Tara
2001 2500LT Suburban 8.1L 4x4 Autoride K/N, AIR HORNS
Reese 12klb w/dual cam, Prodigy, 27x Wilderness BH Trojan 125's, Honda EU3000, Dish 500, Xantrax 1200, Wilson Cellular Ant & Amp, L.I.B.B.A. #1747, Wireless WiFi, Water Camper
bpounds
Whittier CA
Posted: 05/31/12 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Huh? The OP asked about both sizes. I would think comparing the features would be spot on topic.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
bushman512003
Posted: 05/31/12 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
The OP? Huh? My every one take a Number it is getting time to pull the pin as spot off topic............................I had a Power Joker 2005 sent it down the road 6.0 is a bad motor Huh?
Page of 5
 > Honda Generators
