RV.Net Open Roads Forum: Tech Issues: Some of my inside lights dont work.
 > Some of my inside lights dont work.
racerzl1
Mississippi
Posted: 05/28/12 09:48am Link  |  Print  |  Notify Moderator
I tried replacing the little #921 bulbs and they still wont come on. Are the any special breakers for the lights ? Any other way to check them? Thanks
Sooner Schooner
On a Roll
Posted: 05/28/12 09:59am Link  |  Print  |  Notify Moderator
Check the automotive type 12 volt fuses in your breaker box/ fuse panel, you may have a blown fuse.
five'er
Canada
Posted: 05/28/12 10:05am Link  |  Print  |  Notify Moderator
your RV will have a mix of fuses and breakers usually in the same location. With a multimeter you can test both light bulbs, wiring and fuses. If you are looking to test the bulb you can place it in another socket and see if it works there. The problem could also be faulty of bad wiring, bad switch etc. Are the bulbs that don't work on the same circut as ones that do? Is there a switch for them on the fixture or the wall? The small lights would be on a fuse as they are 12v but likely all lights in that section of the RV are on teh same one so if just some don't work likely something else is the cause.
Billieg2
Gone from this forum
Posted: 05/28/12 12:13pm Link  |  Print  |  Notify Moderator
Those bulbs only go in 1 way. Turn it around if it doesn't light. If it still doesn't light take a pen and move the wire inside so it's in the center.
In my life I've spent my money on women, booze, Harleys, guitars and traveling, the rest I just wasted...
2007 Ford F-350 diesel/dually & Sunnybrook Titan KSRV 39-1 Toy hauler 5th wheel hauling my custom Harley
rjf7g
Virginia
Posted: 05/28/12 02:40pm Link  |  Print  |  Notify Moderator
Are you sure the lights aren't also controlled by a wall switch?
2006 Palomino Puma 27FQ Bunkhouse
2007 Gulfstream Innsbruck 36FRS Park Trailer
KSadler1
Albuquerque, NM
Posted: 05/28/12 02:52pm Link  |  Print  |  Notify Moderator
How long have you had the RV? Are you sure these are not the ones that work only when the RV is plugged in or on a generator? The lights in my slide only worked on 110v.....
Ken
2008 Ford F250 XLT Super Duty SB Crew Cab 6.8L V-10 4x4 4:10
(former 5er owner)
racerzl1
Mississippi
Posted: 05/28/12 02:58pm Link  |  Print  |  Notify Moderator
All the fuses are good. I just checked them with a meter.
I do think I have checked all the wall switches.But, I will check again. The RV is hooked up to 120vac ,but i thought the inverter worked all these lights.
Two of the lights that are not working are on the slide out, but there is another there on the slide that does work.
The third light that is not working is up forward in the bedroom,over the fifth wheel area.
dyb
s.c.
Posted: 05/28/12 03:00pm Link  |  Print  |  Notify Moderator
I have a wall switch for the ceiling lights in the living room.
2005 F 250 5.4, 4.10 Gear, Tow/Haul, TorqShift Tranny 8ft. Box
Built in Break Controller
Super Duty super cab 158" wheel base
Eagle 320 rlds 2008
Raised Oct, 1988
Reese Dual Cam
racerzl1
Mississippi
Posted: 05/28/12 03:03pm Link  |  Print  |  Notify Moderator
Yes sir, thanks. I have one too. It is on. I have the ceiling fan on now.
sirdrakejr
Las Vegas, Nevada
Posted: 05/28/12 07:41pm Link  |  Print  |  Notify Moderator
Moved from 5th wheels to tech issues.
Frank
