RV.Net Open Roads Forum: Class A Motorhomes: Engine Air Conditioner Problem 2005 Meridian
 > Engine Air Conditioner Problem 2005 Meridian
Purpleheart
Redondo Beach, California, USA
Posted: 06/05/12 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2005 Itasca Meridian Diesel.
The engine air conditioner is blowing air but is not cooling. What can it be? Where is the unit located?
Thanks for any help.
Purpleheart
2005 Meridian Itasca Class A Motorhome
2005 Honda Pilot
wolfe10
Posted: 06/05/12 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Very similar to the one on your car. Engine driven compressor, an evaporator and condenser and lots of hose.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
donn0128
Pronounced Ore-gun
Posted: 06/05/12 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Fuse blown due to a locked compressor. Low on freon doe to a leak. Engine air is driven by accessory belt on the motor.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Jim@HiTek
Gresham, OR, USA
Posted: 06/05/12 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Good news is that you can pick your time and place when (or if) you get it fixed. Most of us without a working dash air just run the genset and rooftop AC to keep cool while driving. Uses around 0.8 gallons per hour. Those newer roof ACs are getting pretty efficient so yours might use less. Oh, yeah, Onan gensets are reputed to have a 10,000 hour life with regular maintenance.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
seatboard
South Carolina
I have the same problem on our 06 Revolution. I tried to add Freon but it didinothing. I gave up and run the gen set while on the road and use the roof cooling system.
Harold and Faye US Navy Retired
2006 Fleetwood Revolution 40LE
400 cat
Bea PA
Waynesboro, PA, USA
Posted: 06/05/12 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
We had that problem with our MH, hose too close to something on the engine and a hole melted in the hose. Either routed wrong from the factory or tec moved it during valve ajustment.
Bea PA
2004 Winnebago Journey
2008 Saturn Vue
1998 Venture Van
Brake Buddy/Remco Pump
2003 Gold Wing 1800 recently triked (Big Red)
JohnnyT
Goshen New York
Posted: 06/06/12 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
The compressor is located in the engine compartment... A simple thing to check is to insure that your evans control valve which controls the heated engine coolant from passing trough the heater core... It a common occurrence for the evan's valve to fail... So even though your sir conditioner is working it cannot overcome the heat produce is the coolant water is flowing through the heater core.
The evans valve will be on your firewall...
JohnnyT
2004 40DS02 Travel Supreme ISL 400
Jeep Grand Cherokee
M&G Brake & Break Away
Blue Ox Aventa LX Tow bar
sd1209
Fallbrook, Ca
Posted: 06/06/12 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
On my MH the engine compressor went out a few mos back, seal was leaking....I took it to the Ford dealer (I had an ext warr) and they replaced the compressor..
In talking to the tech who works on a/c issues quite a bit, he said that he sees many a/c compressors in MH's go out, esp seal issues.....Much more than in cars...(this dealership works on alot of MH's)...His opinion was that they get used so infrequently that they go bad due to lack of regualr use..His recommendation was to use the a/c regularly, even if not needed..He thought that using it for a minimum of half an hour every time you take the MH out might make the a/c work better and last longer....
Made sense to me so I do.....
Steve and Liz
Fallbrook, Ca
2006 Gulfstream Independence 30' 3 slides....V-10...
2010 Wrangler w/Blue Ox Towbar, Baseplate and braking system
rvrepairnut
bc
Posted: 06/06/12 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
JohnnyT
Much simpler to turn the AC on Max and to coldest setting and then go back and see if compressor runs.That will eliminate a lot of guess work
