RV.Net Open Roads Forum: Class A Motorhomes: serpentine belt
 > serpentine belt
STEVEP220
VA.
Posted: 06/10/12 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
I would like to know about how long a serpentine belt should last before it needed to be replaced. I have 2005 cummins ISB 300hp with 21,000 miles.
ole trucker
Florida.
Posted: 06/10/12 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
I would think about 10 years and replace regardless, but have a spare just in case.
Will's '00 Endeavor
38wdd,01 2500HD
LIVALIL
Oh,I used to be disgusted, but now I try to be amused-
Elvis Costello
bluwtr49
Green Valley, AZ
Posted: 06/10/12 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
i can't imagine that wouldn't last 8-10 years anyway. How often does the one in your car fail??? Should be comparble.
I don't bother carrying a spare as all it drives is the alternator and AC compressor, both of which I can live without for a period of time.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
usmohls2@yahoo.com
CA
Posted: 06/10/12 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
I change the serpentine every 4 to5 years. It is exposed to a lot of heat under the hood. It's rubber & will dry out & crack.
rvrepairnut
bc
Posted: 06/10/12 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
Its hardley broke in at 21K miles but when u see cracks evry 3/4 inch and or can by hand turn the belt sideways by using a tumb and finger with little efort change it
Chuck&Gail
In the Colorado Mountains
Posted: 06/10/12 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
In my car it lasts about 80,000 to 100,000 miles.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
Pogoil
Oregon Coast
Posted: 06/10/12 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Get a Gates or Dayco belt. The Gatorback is too thin and will not last.
Keep a back up 10 minutes to change one.
Changed one out last year on a camping trip. Opened the motor compartment and the Gatorback was half shredded.
On our 1995 Beaver the belt drives the water pump, cant go far with out it.
Pogoil.
klm
SIOUX FALLS, SD
Posted: 06/10/12 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
Just had mine changed out - was fraying - now it is the spare. cummins 5.9 ISB - '02 coach - 84k miles
'02 KOUNTRY STAR DP
2012 HONDA FIT "PUMPKINMOBILE"
GILLIGAN- 1ST MATE CAT - 3 HR TOUR
othertonka
Stockton, CA
Posted: 06/10/12 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Regardless of when you should change the serp. belt, it is imperative that you find the belt routing diagram for your engine. If you can't find the diagram draw one up yourself and/or take a picture now before the belt breaks. After the belt is gone it is real hard to figure out the routing. Just a thought, I drew a diagram for mine.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
RayChez
Barstow, Ca. USA
Posted: 06/10/12 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
It is a job and a half to change it on the 3126-E Cat engine. Once I see cracks on the rubber I will take it to Freightliner to change it out. I believe they will have to remove the air cleaner and part of the duct to be able to get to it on mine. That is what is bad about rear radiators.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
 > serpentine belt
