RV.Net Open Roads Forum: General RVing Issues: Cleaning rear curtains
 > Cleaning rear curtains
salem
Central Valley, Ca
Posted: 06/12/12 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
We have a wide window across the rear of the 5er. It has those curtains that are like cloth strips and operate by pulling a rod to open or to close. They are getting a bit dirty. What do you folks use to clean them? Just a damp sponge or cloth, or some type of cleaner? Thanks
sdianel
Tampa, FL
Posted: 06/12/12 11:09pm Link  |  Quote  |  Print  |  Notify Moderator
we have used carpet foam or upholstery cleaner with Oxy Clean. Test small area to make sure it doesn't leave water spots.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
salem
Central Valley, Ca
Posted: 06/13/12 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Lonny & Diane.
Jumbo One
Seattle
Posted: 06/14/12 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
If they need a heavier cleaning, we remove the blinds and soak them in the bathtub using an Oxi-clean solution. Just make sure you get them rinsed thoroughly...
Opie431
Bellevue, MI
Posted: 06/15/12 04:46am Link  |  Quote  |  Print  |  Notify Moderator
If you use the bathtub method of cleaning put some vinegar in the rinse water to get the soap out.
