RV.Net Open Roads Forum: Fifth-Wheels: Why aren't my brakes working?
 > Why aren't my brakes working?
twins89
Western New York
Posted: 06/17/12 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
We just got a new to us 2000 f350 dually from a friend who traded his FW for MH. It was all set or so we thought. We cannot get the brakes to become engaged wtih the 7 pin. The brakes worked fine with our old truck (at least I think they did - heard them click) Any suggestions on where to begin to look for the problem; controller, 7 pin etc. The lights on the FW worked fine.
Parents who still don't know anything
Twin college graduates who know everything
One lazy Westie
2000 F350 DRW 7.3 PSD crew cab
2007 Jayco Eagle 291 RLTS
2003 Coleman Sedona towed by 99 4Runner for the "graduates"
Chiefcpo
Huntsville, Alabama
Posted: 06/17/12 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Does it have a built in trailer brake controller of did the previous owners take it out as it was portable/aftermarker installed. You did not say as that is a starting point. (Yes some of the 2000 did not have them) next is to check the fuses. then check output from the & pin for voltage (above 10 volts depending on the controller you have).
RoyB
King George, VA
Posted: 06/17/12 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
most of the time you can a tone like thing if you put your head down real close to the trailer wheel when you have someone engage the trailer brakes. If you jake up one side of the trailer the brake will not engage until it is rotated about a 1/4 of a turn on the wheel. Some kind of mechanical thing involved here... You should hear the tone type of sound however without jacking up the wheel on the trailer.
First thing however is look for the brake controller in the truck. Like the other post indicated it may have been removed by the previous owner. Need to look for a manual paddle squeeze switch near your right hand down close to the knee area of the dash... When you are connected and squeeze the switch all the way you should see around 10.0 indicated on the display. If you are not connected to the trailer mine will say "not connected" or something like that...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
Dave&Monica
Ontario
Posted: 06/17/12 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Did you check to see if you have 12V on the brake pin of the connecter on your truck?
Dave
2010 Rockwood 8280WS
2008 F250 CC Lariat SB 6.8L V10
Sooner Schooner
On a Roll
Posted: 06/18/12 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Sometimes it's as simple as not getting a good connection, I've had to pull the plug, and put it back in more securely. Also, check for corrosion on the contacts.
Mile High
Denver, CO
Posted: 06/18/12 10:18am Link  |  Quote  |  Print  |  Notify Moderator
I don't think Ford came out with the integrated brake controller until around 2005.
Agree - just start tracing back with a test light. The brake output wire is typically blue.
You should be able to stop the rig with the trailer brakes while traveling around 5mph. If not, somthing is wrong.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
partsman01
Poco British Columbia
Posted: 06/18/12 11:51am Link  |  Quote  |  Print  |  Notify Moderator
have someone put the brakes on and hold a compass by each wheel and see what happens, the compass should react when power comes to the wheel, or you can check amperage at each wheel.
* This post was edited 06/18/12 12:14pm by partsman01 *
Mile High
Denver, CO
Posted: 06/18/12 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
partsman01 wrote:
have someone put the brakes on and hold a magnet by each wheel and see what happens, the compass should react when power comes to the wheel, or you can check amperage at each wheel.
I think you meant hold a compass by each wheel.
partsman01
Posted: 06/18/12 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I changed it, thanks.
Should not try and be on when I am at work, have to type without getting caught during work.
64thunderbolt
Az
Posted: 06/18/12 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
is your new trailer a 3 axle? My friend just went through this. He had an older controller and it would not support 3 axles. He had to replace it with a new one that would.
Glen
04 Tail gator XT 34' 5th wheel garage model
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" turbo back exh sys
trucool trans cooler added
08 Arctic Cat Prowler 700XTX
