RV.Net Open Roads Forum: Towing: Usable Life of a Truck
Search only in Towing
Open Roads Forum  >  Towing
 > Usable Life of a Truck
Page of 5
Wanderingman
Aransas Pass, TX, USA
Posted: 06/18/12 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
We've upgraded our RV from an '06 Savoy to a '12 Rockwood. But I'm still driving my 2004 F250 Diesel.
It's got 150,000 miles on it. I know the engine will run forever, but I'm concerned about other things, like body integrety, rear axle, transmission, etc.
I've recently replaced the running boards because of rust, but an not aware of any other rust problems.
My A/C went out during the last trip for the second time in a month.
The dealer told me I may need to replace my brakes during the last oil change.
All little stuff, so far.
So any thoughts on the safe, useable life of RV towing for a truck?
Thanks,
-WM
Rockwood Signature Ultra Light 5th Wheel 8280WS
2004 F250 CC, PSD, SB
B&W Companion Hitch
Wife: Kathy (not property, but she didn't want to be left out)
2 doxies: PD & Frank
jerem0621
Sequatchie, TN
Posted: 06/18/12 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
Your truck isn't even broke in yet. It's ok to invest a few grand in wear components and keep her going strong.
Nothing wrong with your mileage.
Now if you are looking for justification from us to buy a new truck.
"you truck is about to fail catostrophically and the ONLY way you can fix it is to buy a new truck!".
Enjoy whatever you decide
Thanks!
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
Wanderingman
Posted: 06/18/12 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
LOL! Thanks.
I've been feeling a little down today.
We took our 3 month old Fiver on it's 4th a trip last week. We got about 20 miles north of home when a guy in an old pick-up sideswiped our truck and the trailer.
Everyone was fine, but the truck and trailer both need body work. Then the A/C broke down in the 95+ heat of central and south Texas. And the mud flap opposite the side of the wreck fell off.
This, after our third trip in which I managed to poke a hole in the rubber roof, and the deadbolt broke.
It just felt like nothing was working, and the urge is to abandon everything and start new!
Rational thought tells me to hang in there, and just fix stuff. But I'm not real rational this week, so I thought I'd do some reality testing by way of this forum!
-WM
BenK
SF BayArea
Posted: 06/18/12 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
My 32 year old 1980 Silverado listed in my sig continues to run...even after
towing a +14K lb utility trailer that bent the Silverado's frame rail during a
hellish ride coming down a windfarm in the Tehachapi Pass (Pajeula Peak, former Arbutus).
It weighed well over 7K lbs, that for a 'heavy half' of it's day with a 6,200 lb GVWR
Praise Dyno Braking shoes and pads with a larger MC & double chamber power assist
Built 5.7L (SS valves, 280 cam, head work, 4 bolt, Edelbrock Performer intake &
carb, etc) along with a built automatic. 3.73's with 33/12.5R15LT load range C's on alloy 15x8's...can still beat up many 'cars' out
on the boulevard when out there cruising after a run to the hardware store...
Think on it's 3rd AC compressor. Also it's 2nd radiator.
HD U-Joints and shocks. 1 ton coil helper springs on the rear axle.
40,000 lb rated ATF cooler in front of the main radiator. Cold, ram air into the
OEM filter canister, which has the OEM over sized air filter.
Silverado was the highest trim level back then...not the model line it is today.
No power anything (crank windows).
It is approaching 500K miles. Sig is old and can't change it...else have to par
it down as the new rules limits the number of characters allowed
Works for me, but most here would have tossed it decades ago. Plus it
has sentimental value...dad gave it to me after abusing it for years
as their mom'n pop grocery/butcher shop truck.
Current TV is a 1996 GMT400 8.6K GVWR Suburban K3500/4x4/7.4L/4.1/SLT (highest
trim level)/etc.
Now in the shop getting a new steering box because I wore out the OEM one.
Was looking at going to diesel, but after reading the futures back in the
early 2000's, decided to avoid the EPA mandated SMOG freight train coming down
the road.
Most likely will NEVER buy new again, as the fashion statement crowd has driven
the new trucks into pure luxury with little of the 'truckness' I like/love/demand
Plus can't work on the new trucks, as the OEMs have dumbed it down by ever increasing
complexity with computer controlled everything.
If me, I'd just keep it and fix whatever till the wheels fall off or
can't/won't fix it anymore. Would still have my 1973 K5 Blazer, but
the body rusted badly and the now Ex said I had to sell it...
Sold my 1970 FJ40 for the K5 because of her...should'a kept the FJ40
and dumped her...
-Ben Picture of my rig
ktmrfs
Portland, Oregon
Posted: 06/18/12 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
neighbor has a F250 7.3 Power stroke, almost 300K miles on it virtually all of it towing a 30' cargo trailer. Other than some normal wear and tear and regualar maintence it's going strong.
2011 Keystone Outback 295RE
2004.5 Silverado 4x4 CC/SB Duramax/Allison
DrBaker
Oklahoma
Posted: 06/18/12 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
I think you can keep most vehicles going as long as you want to drive them.
Nothing wrong with getting a new one just because you want it.....or in my case because the DW didn't want to ride around in my old truck.
2011 Chevy 2500HD CC/SB 4x4 Victory Red
2003 Crossroads Cruiser CF27RL
Champion Screamer, Reese 16k, and a Blue Status Symbol
BobsYourUncle
Surrey, BC Canada
Posted: 06/18/12 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
I drove my 78 Chev 3/4 ton for 26 years and over half a million on the clock.
It still ran good and was very reliable when I quit driving it.
Only reason I retired it is because I just simply got tired of it and wanted something different. My next truck was my first diesel dually
Duramax / Allison
Fire Red
95 Sportsmen 25.5' TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Bob's Trucks
Check Out My Rebuild Project
Project Feedback
ScottG
Bothell Wa.
Posted: 06/18/12 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
150k seems pretty low miles for a modern truck ~ I wouldn't worry about it!
Scott, Grace and Wesly
H0NDA eu2000i
N3YMY
Brunswick, MD
Posted: 06/18/12 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
You worry too much.
...and people vastly under estimate vehicle life today.
I have a 1996 tacoma, 300k miles, factory clutch.
It's been used hard all it's life: towing, hauling stone, dirt, overloaded etc.
This last year the head gasket failed and I had them replaced.
While they had the heads off I had them measure all 6 cylinders: TDC, BDC and mid travel; six points at each location.
All wearing in spec and round (ie not oval requiring bore over).
Also no sludge, etc and I do 10k mile oil changes.
basically, that tells me if I need a clutch or a transmission and the clock says less than 600k, I'm doing it.
It may be old, but it's paid for ...
Wanderingman
Posted: 06/18/12 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
N3YMY wrote:
You worry too much.
Yup!
Page of 5
