bobcoursen
Bellville, ohio
In 06' had Airlift System with Rancho 9000XL and Airbags put on my 05' Dodge Diesel 4WD truck. 3 years ago 1 bag broke so went to Edmonton Canada Lance dealer.(only Choice). He removed both bags and put timbrens on. That worked for 3 more years until this year when both left front and rear air shocks rusted at the top and blew. Need replacement shocks and getting advice like "put back on original shocks with the timberns" to "adjustable shocks without the air but with hand adjustable settings. Lance 1191max takes the weight to the maximum GVWR of 12,200 lbs. Any suggestions here? Orig. Lance dealer says take cab controlled air system out and put hand adjustable on. what you say?
Bob Coursen
BradW
Mayor of Flat Rock
bobcoursen wrote: Lance dealer says take cab controlled air system out and put hand adjustable on.
I don't like the in-cab controller for 9000s. But the manual knobs will rust and eventually lock up also.
You are aware that Rancho 9000s have a lifetime garentee? Send them back with a copy of your receipt and they will send you brand new shocks.
Brad
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos
17oaks
17 Oaks Ranch
Man control knobs are plastic and should not rust.
Keep the 9000 shocks!! I have rum the on ever rig I own, installed many sets in me 4 x4 shop, never had a problem in 10+ years.
Keep the in cab control. If installed correctly it will be trouble free.
Don
17 Oaks Ranch, Texas
US Army (RET)
'11 F350 4x4, CC, LWB, DRW, Lariat
AF 1150, solar, satellite
Vietnam Combat Veteran
SoCalDesertRider
SanDiego, CA, USA
Are you talking about adjustable Rancho 9000 shocks, or air shocks. Ranchos are not air shocks. They are gas/oil shocks that have adjustable oil damping. There is no air inside the shocks.
If you have actual old school air shocks that you pump up with an air compressor, get rid of them. The shock mounts were never intended to support the loaded weight of the truck. That is what the springs are for.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
bobcoursen
Bellville, ohio
Ok, I can see the hand adjustable Ranchos on the back. But, being unfamiliar with the hand adjustable, is it possible to manually adjust reaching through the springs on the front to the knobs to turn them when they are encased within the spring? Looking at it I dont think so but really dont know. It seems the cab control would work, as they seem to have done at least to this point. There has got to be someone in my area who has the answers but am having trouble finding them. I don't know diddly about them. Would stock heavy duty shocks work for the front with adjustables on the back?
SoCalDesertRider
SanDiego, CA, USA
Plain old non-adjustable heavy duty shocks from Bilstein or KYB or Monroe will work just fine up front, and in the rear too. I've run Bilstein shocks up front on my truck for years. I used to run the Ranchos in the rear, but replaced them with Bilsteins when they wore out because I just don't need the adjustable feature in the rear. The Ranchos were nice and worked fine when I had them. I prefer the Bilsteins though and they are a bit less expensive too.
17oaks
17 Oaks Ranch
SoCalDesertRider wrote: Are you talking about adjustable Rancho 9000 shocks, or air shocks. Ranchos are not air shocks. They are gas/oil shocks that have adjustable oil damping. There is no air inside the shocks.
NO they are NOT air shocks, however they use an AIR COMPRESSOR to make ADJUSTMENTS to the variable settings (9 stages) from inside the cab.
17oaks
17 Oaks Ranch
bobcoursen wrote: Ok, I can see the hand adjustable Ranchos on the back. But, being unfamiliar with the hand adjustable, is it possible to manually adjust reaching through the springs on the front to the knobs to turn them when they are encased within the spring? Looking at it I dont think so but really dont know. It seems the cab control would work, as they seem to have done at least to this point. There has got to be someone in my area who has the answers but am having trouble finding them. I don't know diddly about them. Would stock heavy duty shocks work for the front with adjustables on the back?
Its all dependent upon where your shocks are located in relationship to your springs. Generally speaking the control knob is accessible with ease...reach down and make the adjustment. I have run them on a lot of rigs and never had any issues getting at the adj knob.
year, make and model of your rig and I will see if I can look it up in the Rancho Master Catalog...
bobcoursen
Bellville, ohio
Don, It is an 05' Dodge 4WD extended cab Dually special ordered back then with heavy duty package, 5.9 diesel. What are your thoughts on the Bilsteins. Boy, it is hard trying to make a decision on what way to go. I wish there was a shop in this area that specializes in this. Both front and back left side went bad as they leak air at the top. Not sure which bilsteins go with it or which Ranchos to put on, the hand adjustable or stick with the cab controlled, as the system is now over 6 years old.
cdl2
ohio
BradW said you've got a lifetime guarantee...........
Also go to the Rancho site, you can find a dealer there.
I put Koni on my "motorhouse" they work great!!!!
'97 Safari Serengeti, 300 Cat ; '89 Lance LC900 w/Stable-Lift
