MR MAC
BOSTON MA
Daughters popup blew a tire, Duro tire was 7 years old, a lot of use and mi., need replacement real quick, would you use Duro's or another brand.
ROBERT L MC INTYRE
Sloop Smitten
San Marcos, CA
7 years is excellent. It was probably dried out. If I got 7 years from a set of tires I would not hesitate to use them again.
1992 Fleetwood Jamboree Rallye 24' M/H
Ford E350 Chassis, 7.5L Engine, E40D Transmission
My other motorhome is a 1978 Catalina 25 Sailboat
Cruising Califonia, Sailing the Pacific!
2oldman
Winchester WA
Posts about Duro in this forum
CKNSLS
Northern Utah
According to the link they are a better Chinese tire. I think the underlying issue for the OP is there is not a lot of weight being carried. I ran Greenball products (Transmasters) on my lighter trailer with no issues what so ever.
Your probably good with just about anyyhing.
fla-gypsy
North Florida
I consider Duro's one of the worst Chinese junk tires available and will never allow another one on a trailer of mine! Was that strong enough? LOL
Serenlyretired
San Fransisco Bay area
Blew all 3 including spare the first year of use. Pure garbage IMO.
camp4ever
CT
Look at Maxxis trailer tires.
2003 Chevy Silverado 2500HD
2004 Ford Explorer w/ Towing Package
2007 Palomino Stampede S-195
bondebond
Searcy, AR
What size of tire are you talking about? If it's the 12" tire, you do NOT have a lot of choice, and in this case, Duro is the best brand.
Due to age, I had to replace the original Duros on my first PUP. I put Kenda and another brand tire or two on afterwards because I couldn't find any Duro tires. They all blew within 1 to 2 years.
Sad to say, but if you're in a 4.80-12 or 5.30-12, you don't have good options. If you're in a larger rim size, then Maxxis or other choices can be better.
Good luck.
This space left intentionally.
2006 Fleetwood Sequoia and mods...one of the tallest highwall pop-ups on the planet after flipping the axle.
JLTN_James
Colorado
I've got 4 years and 10,000+ miles on my Carlisle Radial Trail tires. 185/80/R13 load range C kept at maximum pressure. My trailer, fully loaded, is about 2300#-2400# and is just under the tire max load (my limiting factor). I usually drive between 60-70 with it and keep it in the garage when not in use. I treat the tires once a year with Black Magic conditioner. So far, I've not had any problems and tread wear is excellent. No sidewall damage or decay.
I'm happy with the Carlisles.
2004 Toyota Tundra SR5 (V8, 4WD, TP, TRD)
2005 Fleetwod Allegance with axle flip
Honeywell 2000i Generator
Me, DW, DS, DD, Dog & Camping Kitty
RetAF
Sumter, SC
I replaced the original tires on my PUP with Duros 4 years ago. I've had no problems and actually have been quite pleased with them. ST185/80D13 is the size I use. You need to pay very close attention to the load carrying ability of the tires and the weight of the PUP. Maxxis tires can't carry enough load (only #1480) in the size that I need. I need the #1660 that the Duros offer.
edited 06/29/12 11:07am by RetAF *
04 Mercury Mountaineer, V8, Tow Package
04 Fleetwood Sequoia
