smiski
vermont
Help trouble shooting why igniting Dometic fridge "RM 1303 ASE
causes a flame up the wall? (this is the original 1984 model in
our Class A Motor Home)
MrWizard
Traveling
switch to electric or manually light it
get this fixed NOW
the ignition is suppose to start before the gas valve opens
this is not happening, your valve is opening, then the ignition is sparking
try cleaning all connections on the board
and clean the tip of the electrode ignitor
you might need a new ignitor electrode and/or a new board
fix NOW before you burn down your RV
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
J Walker
Oakton, Va
Check to see if the gas valve even shuts off. It could be always open and the igniter lights all of accumulated gas. One indication that this is what is happening is that there seems to be a large amount of gas present when the igniter goes off. The shut off valve should be replaceable.
Jim Walker
2000 34' Damon Ultrasport DP
2009 Malibu
Brake Buddy
smiski
vermont
Thank You very much -- those helped. We were able to find some info
on this model of fridge but not much.
