mr. ed
Madison, SD (but usually elsewhere)
I thought I'd post this question because in five years I've never found any sign of water in my diesel when I drain the filter, and I inspect it closely. It's supposed to be drained about once a month but I must admit that since I've never seen water I sometimes go a little longer (my bad). Am I one of the few or are there others out there who have never seen water in their fuel? I wonder how common water contamination is? I know, this is not an excuse for being slack on filter drainage. Stuff does happen!
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
agesilaus
North Florida
Not so far, I've been checking it a couple of times a week. But I only have 10K on this truck.
Glendale Titanium 29E34TS fifth wheel
PullRite OE Series Super5th 18K
Superbumper
fordsooperdooty
Water in diesel fuel can come from leaky underground fuel storage tanks, or as part of the process in making diesel fuel, after the distillation process the fuel is "water washed", then pumped into storage tanks. When the diesel is pumped out to the waiting fuel delivert trucks, it is common for the diesel storage tnks to have as much as 6" of water in the bottoms of the tank.
If the tanks are accidently pumped dry, that water can be in the fuel supply delivered to your gas station. And then into your truck. Even small quantities of water an cause rust, corrosion, extensive damage to the extremely high pressure fuel systems, etc. BAD! VERY BAD!
So the water seperator does it's job, and this is why the filter needs to be changed at recommended frequencies. Or even more often in some areas
And by the way...a fuel injector pump runs around $800.00, and fuel injectors run around 1500.00 for a set of 8. And labor costs are crazy!
ScottG
Bothell Wa.
I've been driving diesel truck since 1989 and have never found water in the fuel.
BTW, High pressure pump (no more injector pumps) is about $1k and a set of 8 injectors run about $5k+.
Scott, Grace and Wesly
H0NDA eu2000i
Perrysburg Dodgeboy
Perrysburg, Ohio USA
In 130,000 miles I have yet to find any water in the bottom of the filter housing. Now about two years ago I changed the fuel pump over to a Air Dog system and completely removed the old stock system which eliminated my WIF light. So now I have been opening the drain valve on the water separation filter just to be safe.
Still have not found any water in the drained fuel though.
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
larry barnhart
wenatchee. wa usa
I have had the water in fuel come on but never could find any water in the fuel when draining or taking fuel out of the tank.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
jmvx2
United States
130,000 miles in my 07 6.7 Cummins Dodge. Never have found a single drop of water.
2007 Dodge 2500 QC 4x4, 6.7 cummins, auto, 3.73 gears, Pullrite rail mount hitch.
08 Jazz 3300(Thor of Ca.) 36', triple slide, King bed, 11,500-12,000lbs
"Don't bad mouth farmers with a full mouth!"
Cummins12V98
on the road
I never drain mine on my 98 or 11. Never found a drop of water when changing filters. That is what the water in fues light is for.
Oh yea the light really does work.
The snow was melting fast and went into the undreground tank i was filling out of. Put about 30 gallons of water and 3 gallons of diesel in and truck was running while fueling and the truck stopped running just before the hose clicked off. Thankfully it was in my 98 Cummins 12 valve so no damage. The station payed me about $1,000 to remove the bed clean out the tank and bleed the lines new filter and full tand of fuel. I had the water in fuel come on twice after that when going around a corner fairly fast and after that never a drop again. Only about a teaspoon each time.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
Chiefcpo
Huntsville, Alabama
Keep your tanks full and there is less surface area for condensation and Pray that the fuel stop has good filters/separators.
path1
seattle
deleted
edited 03/10/13 11:44pm by path1 *
(To cheap to buy new)
1990 37 ft 5th wheel that hasn't moved since 1996 (our best home)
1997 33 ft trailer (winter home in much warmer climate)
2005 25 ft M/H (our "stand up B" for traveling)
