RV.Net Open Roads Forum: Truck Campers: Dometic refrigerator removal
 > Dometic refrigerator removal
Nuugie
Maryland
Posted: 07/16/12 08:19am Link  |  Quote  |  Print  |  Notify Moderator
My refrigerator failed & I want to replace it with a residential refrigerator. The Dometic refrigerator in my Caribou truck camper won't fit through the door. How do you get it out of the camper?
Johnworth914
USA!
Posted: 07/16/12 08:34am Link  |  Quote  |  Print  |  Notify Moderator
You might might be able to remove a window and get it out that hole.
I have seen a few, however, where there was NO way to get it out, as the fridge had been installed before the walls went together.
Alaska is next! Still trying to fit the pontoons to the RV so We can get to Hawaii!
ScottG
Bothell Wa.
Posted: 07/16/12 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Sometimes you can just remove the door frame and other times a whole window has to be removed. If you TC has a slide then it may have gone in before that was installed. There's not much to the fridge and it could easily be cut up into smaller pieces to get it out if you wont ever need it again.
Now how your going to get the new one in is another question!
Scott, Grace and Wesly
H0NDA eu2000i
nm1oqrz
Trumbull CT
Posted: 07/16/12 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Hello. I haven't figured out why the truck camper mfg put such a small door opening in the rigs. I had to remove the cooling unit from the back of refer, then it will fit through the door.
Good luck nm1oqrz
c.traveler2
Moreno Valley,Ca.
Posted: 07/16/12 09:52am Link  |  Quote  |  Print  |  Notify Moderator
Have you measured the escape hatch over the bed, is the opening large enought to pull your refrigerator thru it. On my Lance815 this openning is large enough to pull my refrigerator thru it and as one poster said you my have to remove the cooling unit.
2007 F-250 4x4 /6.0 PSD/ext cab/LB/camper pkg..Lance 815/ 85 watts solar panel
Travelingman2 Photo Website
Truck Camper Trip Reports
Reddog1
El Dorado, CA
Posted: 07/16/12 10:22am Link  |  Quote  |  Print  |  Notify Moderator
I have wondered why some folks can get their refrigerator out the door, with the door frame removed, and others cannot. I haven't measured, but at first glance, all of the doors look to be the same size. Some have rounded corners at the top, others square, but the size looks the same.
The refrigerators do vary in size, but I wonder if the front to rear is different?
I had the coil changed on my refrigerator, a few years ago, and it was done on the dinning table, with the table down. It may or may not have fit through the door with the frame removed. It did not fit through the door with the frame in place.
Wayne
btggraphix
Golden, CO
Posted: 07/16/12 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Someone else on here, I think maybe SABconsulting, had to cut up/disassemble his old fridge to get it out if I recall right, but yes, the bigger question becomes getting the new one in!
raggmann
Botha,Alberta
Posted: 07/16/12 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
I just took mine out.
On the fridge I had to remove the hindge plate on top, latch plate on top and the complete lower trim-12 screws total and it fit thru the door no problem.
Live like you ain't afraid to die and don't be scared, just enjoy your ride
1993 Dodge W250 CTD Club Cab with a 4" lift & 35's
1975(?) Skylark 9'TC
2009 Harley-Davidson Softail Deluxe
sabconsulting
High Wycombe, UK
Posted: 07/16/12 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem, but found by removing the frame etc. it would fit through the door.
My replacement fridge was luckily narrower:
Removing the fridge
Steve.
'07 Ford Ranger XLT Supercab diesel + '91 Shadow Cruiser - Sky Cruiser 1
'92 Suzuki Samurai 4x4 1.6
'09 Fiat Panda 1.2
'10 Citroen DS3 1.6 turbo
c.traveler2
Moreno Valley,Ca.
Posted: 07/16/12 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
Removing the fridge
Steve.
Good job on the refrigerator replacement.
