RV.Net Open Roads Forum: Technology Corner: Suddenlink cable modem on the road
 > Suddenlink cable modem on the road
KC8RXQ
Beaver, WV
Posted: 07/17/12 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
My employer provides internet service to my home as well as Vonage phone and FAX. I would like to know if it would be feasible to use the "home" cable modem at campground sites that provide cable hookups or if there would be system compatability problems. If I could get this to work it would make travelling and working on the road a real possibility.
Thanks,
Ed
Ed and Robin
Travelling buddies: Li Ming, Nina, and Kit
TV: 2010 F350, 6.4L PSD, CC, SWB, 4WD, 3.55 ratio
Banks Six Gun package w/Banks IQ
RV: 2012 Open Range 386FLR 5th wheel
USARMYCW
TEXAS or somewhere in between
Posted: 07/17/12 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
As far as I know, the cable modem is tied to an address and can't be moved around.
HappyKayakers
Black River Falls WI
Posted: 07/17/12 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
It might work if the same provider did cable at the campground. But they would still have to turn on the service and might charge extra, assuming they allow moving the box around in their area. Going out of their area, you'd be SOL.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
ch-ta
MN
Posted: 07/17/12 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
Generally a cable modem will work anywhere in a cable system. 2 things though - the cable system at the CG has to be by the same cable provider, and also has to be fed from the same head end (site where all the dishes and towers are). Not recomended, and not sure if it is really worth the hassle. BTW, cable operators have monitoring tools for modems in their systems, so they WILL know where in the cable plant the modem is when it is online - and yes, they can shut it down remotely if they feel you are in violation of their policy.
2012 Chevrolet Silverado 2500HD CC 4WD LTZ
2013 Keystone Sprinter 266RBS
KC8RXQ
Beaver, WV
Posted: 07/18/12 05:57am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the responses. I appreciate the feedback to the topic and if the moderator wishes, the post can now be closed.
Regards,
netaq
Atlanta, GA
Posted: 07/18/12 09:56am Link  |  Quote  |  Print  |  Notify Moderator
You'd get more satisfactory results by using smartphone wifi tethering or one of those data hotspot devices from a cellular carrier. I use the smartphone hotspot method to get internet on a computer, an ipad, & a kindle fire.
You could switch a home wifi router to access point mode, connect it to the hotspot, and then have cat5 connections available for devices which aren't wifi enabled.
2012 Ford F-250 XLT 6.2 FX4
2012 Keystone Cougar HC321RES
